Hi Jeff,
This problem is definitely interesting. Since, this no longer occurs
under EPICS R3.14.11
What has changed on your end in R3.14 branch?
By the way it also breaks for vxWorks 6.6 as well.
So, maybe you can reproduce on your end.
/afs/slac/package/vxworks/devel/6.6/gnu/4.1.2-vxworks-6.6/x86-linux2/bin/ccppc
-c -DCPU=PPC604 -DvxWorks -include
/afs/slac/package/vxworks/devel/6.6/vxworks-6.6/target/h/vxWorks.h
-O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall
-fno-builtin -MMD -I. -I../O.Common -I. -I..
-I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket
-I../../../../src/cas/generic/st -I../../../../src/cas/../ca
-I../../../../include/os/vxWorks -I../../../../include
-I/afs/slac/package/vxworks/devel/6.6/vxworks-6.6/target/h
-I/afs/slac/package/vxworks/devel/6.6/vxworks-6.6/target/h/wrn/coreip
../../../../src/cas/generic/st/casStreamOS.cc
../../../../src/cas/generic/st/casStreamOS.cc: In member function
'virtual epicsTimerNotify::expireStatus casStreamIOWakeup::expire(const
epicsTime&)':
../../../../src/cas/generic/st/casStreamOS.cc:283: error: unable to find
a register to spill in class 'FLOAT_REGS'
../../../../src/cas/generic/st/casStreamOS.cc:283: error: this is the insn:
(insn:HI 489 488 667 47 (set (reg:DF 120 [ SR$1349 ])
(mem/s/c:DF (plus:SI (reg/f:SI 113 sfp)
(const_int 16 [0x10])) [66 D.20683.delay+0 S8 A128]))
301 {*movdf_hardfloat32} (insn_list:REG_DEP_ANTI 488 (nil))
(nil))
../../../../src/cas/generic/st/casStreamOS.cc:283: confused by earlier
errors, bailing out
make[4]: *** [casStreamOS.o] Error 1
make[4]: Leaving directory
`/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src/cas/build/O.vxWorks-ppc604_long'
make[3]: *** [install.vxWorks-ppc604_long] Error 2
make[3]: Leaving directory
`/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src/cas/build'
make[2]: *** [build.install] Error 2
make[2]: Leaving directory
`/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src/cas'
make[1]: *** [cas.install] Error 2
make[1]: Leaving directory
`/afs/slac.stanford.edu/g/lcls/vol8/epics/base/base-R3-14-12/src'
make: *** [src.install] Error 2
Jeff Hill wrote:
Ernest,
One has to wonder if WRS runs the regression tests on
their vxWorks variants of the GNU compilers.
If this keeps causing problems then perhaps we should
push the toothpaste in the tube at that spot in the source
code where the compiler has troubles.
I checked with Eric and we don’t have vxWorks 6.8 installed here
but Eric mentioned that he was fairly certain that they might
have it installed at the APS, and if so perhaps I could
log in up there and have a look at the issue.
I wonder if the APS has seen this issue since they maybe have
vxWorks 6.8 there? Does the problem occur when the vxWorks
6.8 gnu compiler isn't patched?
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
-----Original Message-----
On
Behalf Of Ernest L. Williams Jr.
Sent: Tuesday, August 31, 2010 9:09 PM
To: Ernest L. Williams Jr.
Cc: EPICS core-talk
Subject: Re: Latest R3.14 branch: build problem with vxWorks 6.8
I applied the following patch from WindRiver:
NAME:GNU 4.1.2 Cumulative Patch for VxWorks 6.7 AND 6.8
(PowerPC)SUMMARY:Latest GNU 4.1.2 Cumulative Patch for VxWorks 6.7 and
6.8 (PowerPC)PRODUCT VERSION:GNU Tools 4.1.2TYPE:PatchDOWNLOADS:1.
cum.vxw6-4.1.2-ppc.2010aug12.zip
<https://support.windriver.com/olsPortal/download?docId=35427&contentId=0210
02
_0001>DESCRIPTION:
I also recall an earlier patch.
So, something is different as I am not getting this problem on EPICS
R3.14.11
Ernest
Ernest L. Williams Jr. wrote:
Latest snapshot of EPICS R3.14.12 does not compile under vxWorks 6.8
on the following target: vxWorks-ppc604
I think Jeff and I have already seen this compiler bug in vxWorks 6.6.
I will confirm that WRS has a compiler patch upstream
/usr/local/lcls/vxWorks/6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc
-include /usr/local/lcls/vxWorks/6.8/vxworks-6.8/target/h/vxWorks.h
-O2 -Wall -mcpu=604 -mstrict-a lign -fno-implicit-fp
-mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I..
-I../../../../src/cas/gene ric
-I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st
-I../../../../src/cas/../ca -I../../ ../../include/os/vxWorks
-I/usr/local/lcls/vxWorks/6.8/vxworks-6.8/target/h -I/u
sr/local/lcls/vxWorks/6.8/vxworks-6.8/target/h/wrn/coreip
sStreamIOWakeup::expire(const epicsTime&)':
a register to spill in class 'FLOAT _REGS'
insn:
(insn:HI 489 488 603 42 (set (reg:DF 120 [ SR$1349 ])
(const_int 16 [0x10])) [66 D.21287.delay+0 S8 A128]))
301 {*movdf_hardfloat32} (insn_list:RE G_DEP_ANTI 488 (nil))
(nil))
errors, bailing out
`/usr/local/lcls/epics/base/base-R3-14-12/src/cas/build/O.vxWorks-
ppc604_long'
`/usr/local/lcls/epics/base/base-R3-14-12/src/cas/build'
`/usr/local/lcls/epics/base/base-R3-14-12/src/cas'
`/usr/local/lcls/epics/base/base-R3-14-12/src'
Cheers,
Ernest
- Latest R3.14 branch: build problem with vxWorks 6.8 Ernest L. Williams Jr.
- Re: Latest R3.14 branch: build problem with vxWorks 6.8 Ernest L. Williams Jr.
- RE: Latest R3.14 branch: build problem with vxWorks 6.8 Jeff Hill
Re: Latest R3.14 branch: build problem with vxWorks 6.8 Andrew Johnson
<2010>
2025
2026
<2010>
2025
2026
