Does CA fully support virtual IPs on a linux host?
Or are we still waiting on the merge fo rsrv and pcas?
References an old tech-talk message:
Message from Tech-talk
/To/: "Hyun Mi, Choi" <[email protected]
<mailto:hmchoi%40kaeri.re.kr>>
/Subject/: *Re: I have a question about using muti IOC*
/From/: Ralph Lange <[email protected]
<mailto:Ralph.Lange%40bessy.de>>
/Date/: Thu, 04 Jan 2007 11:56:40 +0100
/Cc/: EPICS Tech Talk <[email protected]
<mailto:tech-talk%40aps.anl.gov>>
/In-reply-to/: <000601c72fb8$a66010b0$a4302b93@LocalHost>
/Organization/: BESSY
/References/: <000601c72fb8$a66010b0$a4302b93@LocalHost>
Hello Choi,
the most straightforward and cleanest way to achieve this:
Configure multiple additional (logical) network interfaces with
different IP addresses that use the same (physical) ethernet card on
your Linux box.
Start each soft IOC pointing its Channel Access Server to a different of
the additional network interfaces, using the environment variables
described in the CA Reference Manual.
That way your multi IOC Linux host really looks like a bunch of separate
IOCs with separate IP addresses. No confusion or problems with shared
ports should occur. Also - seen from the CA client side - you always
know which of the soft IOCs you are connected to, as you can distinguish
them by IP numbers.
- Re: Channel Access and Virtual IPs Ralph Lange
Re: msi again Goetz Pfeiffer
<2010>
2025
2026
[Merge] lp:~epics-core/epics-base/apple-ios into lp:epics-base noreply
<2010>
2025
2026
