2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base
Date: Wed, 20 Oct 2010 10:01:51 -0000
10 seconds for the maximum delay is as arbitrary as any other value, except probably the maximum double value. But I think it is more reasonable. It is not worth the effort to implement a new field for this. Note that is is only the display limit, not the max value you can set.
indexof () has a different implementation for each record. Thus putting it into xxxRecord.h would break any device support that includes two or more different record headers in the same source code.
https://code.launchpad.net/~dirk.zimoch/epics-base/non-val-attributes/+merge/26189
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base.
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Timo Korhonen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base Dirk Zimoch
Next: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
