Yes.
On 22 Oct 2010, at 06:42 , Ralph Lange wrote:
> On 21.10.2010 21:25, Ben Franksen wrote:
>> Yes. I use this record type heavily for all sorts of conversion tasks.
>> It is one of the most-reused pieces of code I have ever written.
>> The cvt record is a lot more flexible than ao. As Ralph indicated, it is
>> not restricted to functions of one input variable, but can also read
>> and interpolate two-dimensional tables, i.e. calculate the output from
>> from two independent inputs. Furthermore, it can load / reload tables
>> at runtime. The actual loading of the table is done asynchronously and
>> proceeds in parallel to the conversion, i.e. conversion continues to
>> run while the table is loaded in the background. Only after the table
>> has successfully been loaded is it swapped in for the old one. This
>> means you can correct or adjust tables in a running system w/o having
>> to stop the feedforward.
> Question to core:
> As we have seen, the conversion problem occurs at many sites, and everyone wrote their own way out by creating a new record type.
> I think it would be safe to say that this type of conversion is an often-needed functionality that the EPICS core record set is missing.
> Should we include one of the solutions - this record or the stuff from asyn, whatever is more generic and appropriate - as part of base?
> ~Ralph
- Re: Lookup table problem Ralph Lange
Re: Lookup table problem Ben Franksen
<2010>
2025
2026
<2010>
2025
2026
