Subject: |
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base |
mdavidsaver <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 25 Oct 2010 16:06:47 -0000 |
> However, there is the new set of drivers that (mainly) Michael Davidsaver at
> BNL is developing. He probably should also take a look to see if and how this
> would affect his implementation (although I think it will be more or less the
> same story - linking hard and soft events.)
Named DB events will cause a small disruption, but the benefit is enough to justify it.
This will only effect me since I am using a longoutRecord instead of an eventRecord. I can't put an eventRecord in an autosave monitor set because it posts the VAL field whenever the event occurs instead of just when the VAL field changes. I could switch to using a stringoutRecord, and restrict 3.14 to strings which can be converted into integers.
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
- Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Timo Korhonen
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Ralph Lange
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base mdavidsaver
<2010>
2025
2026
[Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
<2010>
2025
2026
