Subject: |
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base |
Dirk Zimoch <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 25 Oct 2010 21:34:42 -0000 |
I modified the code to run with O(1) in most cases. Only if the event name actually changed, the event list is searched. Checking for change costs only one strcmp when the value did not change. The check is only done if event.VAL or calcout.VAL is read though event.INP or event.SIOL.
I also replaced the semaphore lock with something quicker.
I will commit the modifications as soon as I have checked everything and have run some tests.
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
- [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
<2010>
2025
2026
<2010>
2025
2026
