2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS tests -- epicsThreadOnce broken?
To: Eric Norum <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Fri, 29 Oct 2010 09:05:46 -0700
please ignore -- I see that I changed the wrong place...
On Oct 29, 2010, at 9:03 AM, Eric Norum wrote:
> No joy:
> === modified file 'src/libCom/test/epicsThreadOnceTest.c'
> --- src/libCom/test/epicsThreadOnceTest.c	2010-10-05 19:27:37 +0000
> +++ src/libCom/test/epicsThreadOnceTest.c	2010-10-29 16:00:56 +0000
> @@ -89,7 +89,7 @@
>             epicsThreadGetStackSize(epicsThreadStackSmall),
>             onceThread, 0);
> -    epicsThreadSleep(0.1);
> +    epicsThreadSleep(1.0);
>     testOk(runCount == NUM_ONCE_THREADS, "runCount = %d", runCount);
>     epicsEventSignal(go);
> ***** epicsThreadOnceTest *****
> 1..11
> ok  1 - runCount = 8
> ok  2 - once-0: initCount = 1
> ok  3 - once-1: initCount = 1
> ok  4 - once-2: initCount = 1
> ok  5 - once-3: initCount = 1
> ok  6 - once-4: initCount = 1
> not ok  7 - doneCount = 4
> ok  8 - once-5: initCount = 1
> # init was run by once-0
> ok  9 - once-6: initCount = 1
> Recursive epicsThreadOnce() initialization
> ok 10 - once-7: initCount = 1
> Thread recurse (0xa010018) can't proceed, suspending.
> ok 11 - Recursive epicsThreadOnce() detected
>    Results
>       Tests: 11
>      Passed:  10 = 90.91%
>      Failed:   1 =  9.09%
> On Oct 29, 2010, at 8:45 AM, Andrew Johnson wrote:
>> On Friday 29 October 2010 10:24:18 Eric Norum wrote:
>>> So can we fix this somehow?    I don't like seeing failure rates greater
>>> than 0.0%.    I'm sure that others running the tests will also be confused
>>> by this, too.
>> Try this:
>> +++ src/libCom/test/epicsThreadOnceTest.c       2010-10-29 15:43:59 +0000
>> @@ -93,7 +93,7 @@
>>    testOk(doneCount == NUM_ONCE_THREADS, "doneCount = %d", doneCount);
>>    testDiag("init was run by %s", initBy);
>>> On Oct 29, 2010, at 8:14 AM, Davidsaver, Michael wrote:
>>>> I think this is noise caused by a test of the recursive once detection.
>>>> If a thread once call recurses the thread is suspended.
>> I completely disagree, the test that failed was run before the recursive
>> detection test.
>> I'm guessing that Eric is using a fairly slow CPU which took longer than 0.1
>> seconds for the ~8 context switches in the test to take place.
>> Please keep these discussions *on* the list, it's there for archival purposes
>> as much as anything; if people don't like the volume they can un-subscribe and
>> just follow tech-talk.
>> - Andrew
>> If a man is offered a fact which goes against his instincts, he will
>> scrutinize it closely, and unless the evidence is overwhelming, he will
>> refuse to believe it.  If, on the other hand, he is offered something
>> which affords a reason for acting in accordance to his instincts, he
>> will accept it even on the slightest evidence.  -- Bertrand Russell
> Eric Norum
> [email protected]
Eric Norum
[email protected]
Re: RTEMS tests -- epicsThreadOnce broken? Andrew Johnson
Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
Prev: Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
Next: Re: RTEMS tests -- epicsThreadOnce broken? Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
