Hi Andrew,
The latest Microsoft compiler complains if there is any class
that is being exported from a dll which has UDT member
data that is not also being exported. This causes problems, for
example, with StandardString which has a std :: string member
data which is not a dll exported class. I don?t know
quite what to do about this particular situation because
exporting std :: string is maybe not a good idea (certainly
there could be multiply defined symbols if more than one dll
actually started doing this). It just may not be a good idea
to embed STL data members in DLL interface classes. One solution
would be to make StandardString into a template (which wouldn?t be
a dll exported class). That would also make it more generally
useful if it were to be based on the same template arguments as
basic_string<charT, traits, Alloc>.
In this context, it occurs to me that it would be quite useful
if we had a global template function like this declared in
BasicString.h which could be used also in the implementation of
StandardString<charT, traits, Alloc>.
template <charT, traits, Alloc>
void append ( std :: string &, const basic_string<charT, traits, Alloc> & );
The global template function almost seems to be a no-brainer so
I will probably go ahead and implement it in the cvs trunk branch so
that I can immediately work around this issue.
I can also morph StandardString into
StandardString<charT, traits, Alloc> as you see fit.
Comments?
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
RE: epicsEvent semantics Jeff Hill
RE: what was the time before 1990? Davidsaver, Michael
<2010>
2025
2026
Re: epicsEvent semantics Eric Norum
Patch to subArray record Michael Abbott
<2010>
2025
2026
