2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.14.12 Issues
To: "Ernest L. Williams Jr." <[email protected]>
Cc: [email protected]
Date: Mon, 22 Nov 2010 11:00:24 -0500
Hi Ernest,
On Saturday 20 November 2010 11:25:52 Ernest L. Williams Jr. wrote:
> I tried the recommendations mentioned in the EPICS Config file for my
> architecture.
> # This one does not work with RHEL 5
> #COMMANDLINE_LIBRARY = READLINE
> # This one works but had to do a clean uninstall and
> # Try again. :)
> COMMANDLINE_LIBRARY = READLINE_NCURSES
I've just modified the wording of the release notes and added some more
comments to the configure/os/CONFIG_SITE.Common.linux-* files.  I will not
change the default setting though, newer Linux versions *do* work with that
default and I don't want to link every binary we build on such systems with
other libraries unnecessarily.
On Saturday 20 November 2010 11:54:19 Ernest L. Williams Jr. wrote:
> In the RELEASE_NOTES for R3-14-12, we have:
>         VxWorks 6.7 support
> Added build support for the latest Wind River release.
> That should say vxWorks 6.8, right?
The 6.7 was correct when I originally wrote it, but I added the 6.8 support
well before the -pre1 release came out (that's the version we're going to be
using here at the APS).  I corrected the release notes a few days ago, adding
a caveat that we do not support vxWorks on SMP systems yet (that's going to
need a fair bit of work).
Thanks for the reports,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Readline Issue Ernest L. Williams Jr.
Prev: Readline Issue Ernest L. Williams Jr.
Next: Any 3.14.12 blockers? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
