2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: configure/ reorganization
To: "J. Lewis Muir" <[email protected]>, [email protected]
Date: Wed, 8 Dec 2010 15:37:55 -0600
Hi Lewis,
On Wednesday 08 December 2010 14:20:38 J. Lewis Muir wrote:
> On 12/8/10 2:06 PM, Andrew Johnson wrote:
> > Michael suggested replacing our build system with CMake, but he did find
> > some issues with doing so and I don't think that's up to the job, and it
> > was not popular in my recent survey (aside from the effort needed to
> > train and support all of the EPICS developers out there in any new
> > system).
> I'd be curious to know what the issues were and why you don't think it's
> up to the job.
Ok, maybe instead of "it's not up to the job" I should have said "the result
would not be as easy for developers to configure as the current build system".
Michael is the best person to say what the issues were, but I'm pretty sure
that he only had it working on Linux and RTEMS.  I don't know whether CMake
runs on all our host architectures, but I'm guessing that supporting the
Microsoft compiler on Windows might take some work; one criterion that I will
insist on is that we not drop any major targets.
You can find Michael's latest version on Launchpad, browse it here:
  http://bazaar.launchpad.net/~mdavidsaver/epics-base/cmake/files
One example about the complexity issue, the CMakeLists.txt files in his src/*
directories do seem to be longer than their companion Makefiles.  I remember
Michael commenting about problems defining macros (routines, ?) for CMake in a
central place, he had to copy some things into every place that needed them
(don't know if that's been fixed since).  I'm not sure if he looked at
building support modules, he doesn't seem to build the src/makeBaseApp
directory at all.
> I'm also hoping you're careful about how much weight you give the survey
> results.  When I pointed out some of the weaknesses in the survey, you
> agreed and noted the results wouldn't be treated too seriously.  But now
> you seem to be using the survey results as a reason for not switching to
> CMake.
I'm using the survey as an indication of how much work it might be to persuade
the community to switch.  I haven't said anything like "over my dead body,"
but there are many things that would need to be solved before we could do so.
The community's reaction to that question tells me that they are probably not
frustrated by the existing build system, or if they are it's not enough to
make them eager to find an alternative.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
RE: configure/ reorganization Davidsaver, Michael
Re: configure/ reorganization Stephen Lewis
src/ reorganization Davidsaver, Michael
Re: configure/ reorganization Andrew Johnson
Re: configure/ reorganization J. Lewis Muir
Prev: RE: configure/ reorganization Jeff Hill
Next: RE: configure/ reorganization Davidsaver, Michael
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: configure/ reorganization J. Lewis Muir
