2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: src/ reorganization
To: <[email protected]>
Date: Fri, 10 Dec 2010 12:47:32 -0500
In the interest of not doing too much at once I'd like to do the
reorganization in stages.  The first stage to be just moving whole
directories.  The second would be file moves.  Third would be merging
the lib*Ioc libraries.  The intent is that to ensure that things remain
buildable after each step.
If there aren't major changes then next week I will create a branch with
these changes and request a merge.
The first stage will look like:
> == Full list of renames
> tools      = tools
> libCom     = libCom
> toolsComm  = libCom/tools
> RTEMS      = libCom/RTEMS
> as         = ioc/as
> bpt        = ioc/bpt
> db         = ioc/db
> dbStatic   = ioc/dbStatic
> dbtools    = ioc/dbtemplate
> misc       = ioc/misc
> registry   = ioc/registry
> rsrv       = ioc/rsrv
> dev/softDev= std/dev
> dev/testDev= std/test
> rec        = std/rec
> softIoc    = std/softIoc
> ca         = ca/client
> cap5       = ca/client/perl
> catools    = ca/client/tools
> cas        = ca/legacy/pcas
> excas      = ca/legacy/pcas/ex
> gdd        = ca/legacy/gdd
> makeBaseApp= template/base
> makeBaseExt= template/ext
> util       = util
Re: src/ reorganization Ben Franksen
Re: src/ reorganization Andrew Johnson
src/ reorganization Davidsaver, Michael
Prev: Re: configure/ reorganization Stephen Lewis
Next: Re: src/ reorganization Ben Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: src/ reorganization Jeff Hill
