Subject: |
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
mdavidsaver <[email protected]> |
Date: |
Fri, 25 Feb 2011 19:46:18 -0000 |
Hi Michael,
I'm currently working on merging your reorganization with my branch that split the libCom/Makefile into multiple fragments that are local to the source files but that get included by the original file. I will repeat this idea in the other src/* directories, which I believe should also make it slightly easier to merge changes across this reorganization boundary.
Did you have any particular reason for putting antelope and flex under libCom/tools rather than directly under libCom? I'm currently inclined to drop the tools layer.
- Andrew (from home, via LP)
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src/+merge/44296
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base.
- Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
<2011>
2025
2026
[Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base noreply
<2011>
2025
2026
