2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Wed, 10 Aug 2011 17:54:31 -0000
On 08/10/2011 11:43 AM, mdavidsaver wrote:
> ...FYI. Debian linux still builds a (by default) i486 toolchain.
I have to correct myself here.  It is called i486-linux-gnu, but it is
built using --with-arch-32=i586 so it seems to be a i586 target.  There
is probably more to it then that...
> $ gcc
> -v
> Using built-in specs.
> Target: i486-linux-gnu
> Configured with: ../src/configure -v --with-pkgversion='Debian
> 4.4.5-8' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs
> --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr
> --program-suffix=-4.4 --enable-shared --enable-multiarch
> --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib
> --without-included-gettext --enable-threads=posix
> --with-gxx-include-dir=/usr/include/c++/4.4 --libdir=/usr/lib
> --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug
> --enable-objc-gc --enable-targets=all --with-arch-32=i586
> --with-tune=generic --enable-checking=release --build=i486-linux-gnu
> --host=i486-linux-gnu --target=i486-linux-gnu
> Thread model: posix
> gcc version 4.4.5 (Debian 4.4.5-8)
And the CaS operations are available.
> $ cpp -dM test.c | egrep
> '86|SYNC'
> #define __i586 1
> #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_1 1
> #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_2 1
> #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_4 1
> #define __GCC_HAVE_SYNC_COMPARE_AND_SWAP_8 1
> #define __DBL_MAX__ 1.7976931348623157e+308
> #define __i386 1
> #define __i586__ 1
> #define __i386__ 1
> #define i386 1
FYI, also for RTEMS powerpc mvme3100
> $ powerpc-rtems4.9-cpp -dM -mcpu=powerpc -msoft-float -D__ppc_generic
> test.c | egrep 'PPC|SYNC'
> #define _ARCH_PPC 1
> #define __PPC__ 1
> #define __PPC 1
> #define PPC 1
And for RTEMS x86 (>=i486).  I don't know about arm though.
https://code.launchpad.net/~epics-core/epics-base/epicsR3.15-atomics/+merge/70642
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base mdavidsaver
Next: RE: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
