2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Thu, 11 Aug 2011 15:06:35 -0000
> Unfortunately -march=i586 sets both a minimum and maximum.
So I did hear this comment.
To clarify, I will elaborate on your concern. If its true that certain Linux distros include a gcc defaulting to other than 386 (I have only looked at RHEL which includes a gcc defaulting to 386) then I agree that our setting it to i586 could be a negative in the future if the local system defaults to some ubiquitous platform with more capabilities such as pentium-II.
So if its true that Linux platforms include a gcc that defaults its arch to some more capable processor then perhaps I should remove the -march=i586 but then I fear that at least some of the (RHEL) linux users will be much less likely to see any benefits from the atomics given the current state of how the build system works.
https://code.launchpad.net/~epics-core/epics-base/epicsR3.15-atomics/+merge/70642
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base.
[Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Next: Re: c++ static initialization Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Andrew Johnson
