2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Fri, 12 Aug 2011 14:46:23 -0000
Jeff Hill wrote:
> So it appears that at this time we don't yet have all of the necessary infrastructure in place for users to choose a specific x86 host architecture when only changing EPICS_HOST_ARCH. Janet: hopefully I am wrong about this and there is an easy solution.
You are correct. We now have the configure files for building
linux-386,linux-486, and linux-586 as cross targets
of a linux-x86 build. We need to add the  CONFIG.linux-nnn.Common and
CONFIG.linux-nnn.linux-nnn files.
This would be fairly simple though because we could just include the
appropriate linux-x86 config file and then
add architecture specific overrides.
Janet
https://code.launchpad.net/~epics-core/epics-base/epicsR3.15-atomics/+merge/70642
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Prev: c++ 0x initialization of local (block scoped) static variables Jeff Hill
Next: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
