2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base 3.14.12.2-pre1 available for testing
Cc: [email protected]
Date: Fri, 25 Nov 2011 11:46:26 +0100
On Monday, November 21, 2011, Andrew Johnson wrote:
> On 2011-11-18 Benjamin Franksen wrote:
> > It may be a bit late but I have attached a very small patch that adds
> > an option -b to dbExpand to enable the relaxed breakpoint table
> > checking on the host side. Please consider merging this into
> > R3.14.12.2.
> Merged, thanks.
Compiling this under windows gives a link error 'symbol dbBptNotMonotonic
not defined'. See https://bugs.launchpad.net/bugs/894276. The solution is to
properly declare this variable in a header file (dbStaticLib.h) with
epicsShareExtern (is the cleaner solution anyway). A patch for this fix is
attached. It solves the problem on Windows for me (32bit VM).
Cheers
Ben
PS: I would have attached the patch together with a comment to the bug
report in the tracker but I could not see how to do that.
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
diff -rN -u old-baseR3.14.12.2/src/dbStatic/dbExpand.c new-baseR3.14.12.2/src/dbStatic/dbExpand.c
--- old-baseR3.14.12.2/src/dbStatic/dbExpand.c	2011-11-25 11:35:06.000000000 +0100
+++ new-baseR3.14.12.2/src/dbStatic/dbExpand.c	2011-11-25 11:35:07.000000000 +0100
@@ -52,7 +52,6 @@
     --argc;
     while ((argc > 1) && (**argv == '-')) {
-        extern int dbBptNotMonotonic;
         char optLtr = (*argv)[1];
         char *optArg;
diff -rN -u old-baseR3.14.12.2/src/dbStatic/dbStaticLib.h new-baseR3.14.12.2/src/dbStatic/dbStaticLib.h
--- old-baseR3.14.12.2/src/dbStatic/dbStaticLib.h	2011-11-25 11:35:06.000000000 +0100
+++ new-baseR3.14.12.2/src/dbStatic/dbStaticLib.h	2011-11-25 11:35:07.000000000 +0100
@@ -74,6 +74,8 @@
 epicsShareFunc void epicsShareAPI dbCopyEntryContents(DBENTRY *pfrom,
     DBENTRY *pto);
+epicsShareExtern int dbBptNotMonotonic;
 epicsShareFunc long epicsShareAPI dbReadDatabase(DBBASE **ppdbbase,
     const char *filename, const char *path, const char *substitutions);
 epicsShareFunc long epicsShareAPI dbReadDatabaseFP(DBBASE **ppdbbase,
Re: EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
Prev: Contribtions for R3.14.12.2-rc1 Andrew Johnson
Next: Re: EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
