2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base
Date: Tue, 10 Jan 2012 15:31:30 -0000
> My first preference for a suitable language would be Lua since the licensing
> is suitable (MIT) and there is a glue layer available for running it on
> vxWorks which allows Lua scripts to call functions found through the vxWorks
> symbol table.  It should be relatively easy to extend Lua to run registered
> iocsh commands as well.
Hi, Andrew.
I'd be fine with Lua, but someone has to do the work.
I have another idea: What if I changed the syntax of my proposed if-statement feature to match that of Lua?  It would be way more restrictive than Lua, and I would likely have to chop some things out of it, but Lua would be a superset such that if someone did do the work to switch to Lua at a later time, existing scripts using my proposed if-statement would continue to work in Lua.  Would that make this branch merge more likely?
Lewis
https://code.launchpad.net/~jlmuir/epics-base/iocsh-if-flow-control-3.14/+merge/87972
Your team EPICS Core Developers is requested to review the proposed merge of lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base.
Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base J. Lewis Muir
Next: Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
