2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.15.0 deadline approaching
To: [email protected]
Date: Wed, 30 May 2012 10:54:11 -0400
Hi Andrew,
I just want to summarize my plans. The branches I'm planning to propose for inclusion are the following. When I
Ralph's server side plugins work. The remaining work is to figure out how best to run the unit tests on RTEMS and vxWorks.
https://code.launchpad.net/~epics-core/epics-base/server-side-plugins
I pushed a few more revisions to
https://code.launchpad.net/~epics-core/epics-base/dontcant
these actually back out some of the changes already merged. This re-adds some uses of cantProceed() to errors which are not allocation failures (epicsMutexMustLock() being one).
I'm also going to propose:
https://code.launchpad.net/~epics-core/epics-base/thread-pool
I think the API at this point is fixed. I'm planning to replace the internal mutexs with something which can be used from interrupt context for RTEMS and vxWorks.
And if I have time
https://code.launchpad.net/~epics-core/epics-base/callback-error
Although I think I will make some changes to this as well. I'm having second thoughts about adding a field to the CALLBACK structure which existing code may not initialize correctly.
Michael
On 5/29/2012 7:04 PM, Andrew Johnson wrote:
Calling all Base 3.15 developers...
According to the 3.15.0 release timetable slide that I presented at the SLAC
meeting, we have a major deadline approaching this Friday:
– All code branches to be considered for inclusion must be
   • published on Launchpad and
   • a merge requested by 2012-06-01 (Friday 1st June)
Since I don't know what the status is of many of the branches published,
please make sure that any major work to be included has had a merge requested.
If it's not quite ready yet that's Ok, just include a note to that effect in
the merge request.
- Andrew
Re: R3.15.0 deadline approaching Michael Davidsaver
Re: R3.15.0 deadline approaching Andrew Johnson
Prev: R3.15.0 deadline approaching Andrew Johnson
Next: Re: R3.15.0 deadline approaching Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
