2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: timer delay compensation
To: Ralph Lange <[email protected]>, Andrew Johnson <[email protected]>
Date: Thu, 14 Jun 2012 01:12:42 +0000
Hi Andrew, Ralph,
We will need to decide how to proceed with the timer delay
compensation issue. I am extremely busy so it will be easy
for this to fall through the cracks.
It occurs to me that this issue could also be fixed by just not
compensating the timer delay when the requested delay is less than one
quantum, but otherwise leaving the compensation code in place. I think
I mentioned that option before, but I suspect that Ralph is in favor only
of a solution that 100% removes the compensation. I mention this
option again only because it would be easier to justify as a backwards
compatible bug fix, and therefore as an R3.14 patch. I believe that
Andrew is not in favor of a change that removes the compensation 100%
from R3.14, and would postpone that change to R3.15.
What do you think? I am happy to implement whatever the community
consensus is.
Jeff
Re: timer delay compensation Eric Norum
Prev: Re: "spinlock" API Andrew Johnson
Next: Re: timer delay compensation Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
