Subject: |
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Ralph Lange <[email protected]> |
Date: |
Fri, 29 Jun 2012 19:20:23 -0000 |
Should the AtThreadExits run before the ExitHooks? You have this in several places:
+ epicsThreadRunExitHooks(pthreadInfo);
epicsExitCallAtThreadExits ();
My feeling is that task-specific clean-up should happen before the generic task clean-up, so things nest nicely.
I think the Win32 calls to the epicsThreadRun*Hooks() routines belong in the epicsWin32ThreadEntry() routine, and epicsThreadHooksInit() should be called towards the bottom of fetchWin32ThreadGlobal() after the atexit() call but before initCompleted gets set (there doesn't look to be anything in the mutex creation code that would cause problems there).
Then with some tests in libCom/test/epicsThreadTest.cpp and comments in the Release Notes I think this should be good to go. Eventually I'll want the API documenting in the AppDevGuide too, but not for this release.
- Andrew
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
- [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base mdavidsaver
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
<2012>
2025
2026
<2012>
2025
2026
