Hi Michael,
On 2012-07-30 Michael Davidsaver wrote:
> I assume you are referring to the gdd::convertOffsetsToAddress? At a
> glance that is all I see (involving unsigned long at least). Is there
> more?
That sounds right, but I haven't looked too deeply as I don't have a win64
system either and I don't want to delay the 3.15.0.1 release any longer.
It would probably be feasible to debug this using the MinGW cross-compiler on
Linux, which I have successfully used to cross-build 32-bit executables (they
cross-compile *much* faster than building on Windows) — the MinGW cross-tools
are packaged on both Ubuntu and Fedora/RHEL. Add a CROSS_COMPILER_TARGET_ARCH
setting and edit the recently-added CONFIG_SITE.linux-x86.win32-x86-mingw file
to set GNU_TARGET and GNU_DIR as necessary. For 64-bit you'll need to add a
CONFIG.linux-x86.windows-x64-mingw file which can probably just include its
32-bit counterpart and override one or two variables to add -m64 to the
compile and link lines.
> I don't have access to a win64 system, but if you send me the log of
> build errors I'll help if I can.
I don't have Janet's errors and she's gone home now. As I said above I don't
think this should hold up the release, which I might even be able to make
tomorrow after some last-minute commits and merging bug-fixes from 3.14.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Building gdd on windows-x64 targets Andrew Johnson
- Re: Building gdd on windows-x64 targets Michael Davidsaver
[Merge] lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base J. Lewis Muir
<2012>
2025
2026
<2012>
2025
2026
