2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: optimization to epicsTime
To: [email protected]
Date: Wed, 14 Nov 2012 15:33:51 -0500
Hi Jeff,
Looks fine to me, don't worry about committing minor changes like this
directly to the 3.15 branch; it's the big changes that need reviewing.
- Andrew
On 2012-11-14 Hill, Jeff wrote:
> Dear All,
> I inadvertently committed the attached change to the main trunk on a
>  checkout instead of a branch and therefore bypassed the normal review
>  process. If there is (any) opposition I will back out the change and make
>  a branch. I did run the epicsTime regression test, which didn't detect any
>  issues, before making this commit.
> Jeff
> Commit message:
> After optimizing the epicsTime::addNanoSec function we now have a larger
>  code which uses only unsigned integer arithmetic. This is for the benefit
>  of embedded cpu's lacking a hardware floating point coprocessor at the
>  expense of some additional code to maintain. I measured the cpu load
>  improving from 40% free to 80% free after making this change, on a nios2
>  soft core processor.
> Change:
> == modified file src/libCom/osi/epicsTime.cpp
> --- src/libCom/osi/epicsTime.cpp	2012-05-03 17:19:34 +0000
> +++ src/libCom/osi/epicsTime.cpp	2012-11-14 19:51:30 +0000
> @@ -113,8 +113,48 @@
>  inline void epicsTime::addNanoSec (long nSecAdj)
> -    double secAdj = static_cast <double> (nSecAdj) / nSecPerSec;
> -    *this += secAdj;
> +    // After optimizing this function we now have a larger
> +    // code which uses only unsigned integer arithmetic.
> +    // This is for the benefit of embedded cpu's lacking
> +    // a hardware floating point coprocessor at the
> +    // expense of some additional code to maintain.
> +    // joh 14-11-2012
> +    if ( nSecAdj >= 0 ) {
> +        unsigned long nSecOffsetLong =
> +              static_cast < unsigned long > ( nSecAdj );
> +        while ( nSecOffsetLong >= nSecPerSec ) {
> +            this->secPastEpoch++; // overflow expected
> +            nSecOffsetLong -= nSecPerSec;
> +        const epicsUInt32 nSecOffset =
> +            static_cast < epicsUInt32 > ( nSecOffsetLong );
> +        epicsUInt32 nSecPerSecRemaining = nSecPerSec - nSecOffset;
> +        if ( this->nSec >= nSecPerSecRemaining ) {
> +            this->nSec -= nSecPerSecRemaining;
> +        else {
> +            this->nSec += nSecOffset;
> +    else {
> +            static_cast <unsigned long> ( -nSecAdj );
> +            this->secPastEpoch--; // underflow expected
> +        if ( this->nSec >= nSecOffset ) {
> +            this->nSec -= nSecOffset;
> +        else {
> +            // borrow
> +            this->nSec += nSecPerSec - nSecOffset;
> Jeff
> ______________________________________________________
> Jeffrey O. Hill           Email        [email protected]
> LANL MS H820              Voice        505 665 1831
> Los Alamos NM 87545 USA   FAX          505 665 5107
> Message content: TSPA
- Andrew
READ CAREFULLY. By reading this email, you agree, on behalf of your
employer, to release me from all obligations and waivers arising from
any and all NON-NEGOTIATED agreements, licenses, terms-of-service,
shrink-wrap, click-wrap, browse-wrap, confidentiality, non-disclosure,
non-compete and acceptable use policies ("BOGUS AGREEMENTS") that I
have entered into with your employer, its partners, licensors, agents
and assigns, in perpetuity, without prejudice to my ongoing rights
and privileges. You further represent that you have the authority to
release me from any BOGUS AGREEMENTS on behalf of your employer.
optimization to epicsTime Hill, Jeff
Prev: RE: optimization to epicsTime Hill, Jeff
Next: catch in ubuntu gcc 4.6.1 Hill, Jeff
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: optimization to epicsTime Hill, Jeff
Next: RE: optimization to epicsTime Hill, Jeff
ANJ, 26 Nov 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
