2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: double buffered waveformRecord
To: EPICS core-talk <[email protected]>
Date: Thu, 03 Jan 2013 17:03:09 -0500
All,
Recently I was looking at how array fields are handled in database processing and RSRV. In the process I noticed a way to allow double buffering (and possible more creative schemes) of BPTR in the waveformRecord.
This involves playing games with the array offset returned by the get_array_info() record support function, and taking advantage of how this offset is used in dbConvert.c. By doing this I can convince dbGet() and dbPut() to read/write from almost arbitrary locations which can change with each call.
static long get_array_info(DBADDR *paddr, long *no_elements, long *offset)
    if(prec->bact) {
        /* cause caller to access buf[1] */
        *offset = (prec->buf[1] - prec->buf[0]) / dbValueSize(prec->ftvl);
    } else {
        *offset = 0;
http://bazaar.launchpad.net/~epics-core/epics-base/array-opt/revision/12397
There is also an example device support.
http://bazaar.launchpad.net/~epics-core/epics-base/array-opt/revision/12398
Now that I have this working I'd like to create a mechanism which doesn't involve abusing 'offset'. So far I've been thinking of allowing get_array_info() to provide a replacement pointer (in addition to offset and length) either by adding another argument, or allowing modification of the DBADDR argument.
Any thoughts/suggestions?
Michael
The entire branch
https://code.launchpad.net/~epics-core/epics-base/array-opt
There is also some in-progress changes related to optimizing dbConvert.c.
Re: double buffered waveformRecord Andrew Johnson
Next: Re: double buffered waveformRecord Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
