2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] lp:~epics-core/epics-base/get-cpus into lp:epics-base
To: [email protected]
Date: Thu, 28 Mar 2013 14:16:20 -0000
Ralph Lange has proposed merging lp:~epics-core/epics-base/get-cpus into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/get-cpus/+merge/155967
Add int epicsThreadGetCPUs() to the epicsThread API.
epicsThreadGetCPUs() returns the number of logical CPUs that are available for the IOC. On systems that use Hyper-Threading, this number may be up to twice the number of physical cores.
The Posix and WIN32 implementations are returning the number of CPUs available for the process, which may be limited by the system.
For the time being, vxWorks just returns 1.
Only tested for Linux. The implementations for RTEMS, vxWorks and WIN32 need testing, please...
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/get-cpus into lp:epics-base.
=== modified file 'src/libCom/osi/epicsThread.h'
--- src/libCom/osi/epicsThread.h	2012-07-06 21:33:10 +0000
+++ src/libCom/osi/epicsThread.h	2013-03-28 14:15:26 +0000
@@ -3,7 +3,7 @@
 *     National Laboratory.
 * Copyright (c) 2002 The Regents of the University of California, as
 *     Operator of Los Alamos National Laboratory.
-* Copyright (c) 2012 ITER Organization
+* Copyright (c) 2013 ITER Organization.
 * EPICS BASE is distributed subject to a Software License Agreement found
 * in file LICENSE that is included with this distribution.
@@ -85,6 +85,7 @@
 epicsShareFunc double epicsShareAPI epicsThreadSleepQuantum(void);
 epicsShareFunc epicsThreadId epicsShareAPI epicsThreadGetIdSelf(void);
 epicsShareFunc epicsThreadId epicsShareAPI epicsThreadGetId(const char *name);
+epicsShareFunc int epicsThreadGetCPUs(void);
 epicsShareFunc const char * epicsShareAPI epicsThreadGetNameSelf(void);
=== modified file 'src/libCom/osi/os/RTEMS/osdThread.c'
--- src/libCom/osi/os/RTEMS/osdThread.c	2012-07-31 19:04:38 +0000
+++ src/libCom/osi/os/RTEMS/osdThread.c	2013-03-28 14:15:26 +0000
@@ -718,3 +718,12 @@
     return 1.0 / rtemsTicksPerSecond_double;
+#if defined(RTEMS_SMP)
+    return rtems_smp_get_number_of_processors();
+#else
+    return 1;
+#endif
=== modified file 'src/libCom/osi/os/WIN32/osdThread.c'
--- src/libCom/osi/os/WIN32/osdThread.c	2012-07-31 19:04:38 +0000
+++ src/libCom/osi/os/WIN32/osdThread.c	2013-03-28 14:15:26 +0000
@@ -1105,6 +1105,14 @@
     return ( void * ) TlsGetValue ( pPvt->key );
+ * epicsThreadGetCPUs ()
+epicsShareFunc int epicsThreadGetCPUs ( void )
+    return atoi(getenv("NUMBER_OF_PROCESSORS"));
 #ifdef TEST_CODES
 void testPriorityMapping ()
=== modified file 'src/libCom/osi/os/posix/osdThread.c'
--- src/libCom/osi/os/posix/osdThread.c	2012-09-20 19:55:32 +0000
+++ src/libCom/osi/os/posix/osdThread.c	2013-03-28 14:15:26 +0000
@@ -3,7 +3,7 @@
@@ -873,3 +873,7 @@
     return 1.0 / hz;
+    return sysconf(_SC_NPROCESSORS_ONLN);
=== modified file 'src/libCom/osi/os/vxWorks/osdThread.c'
--- src/libCom/osi/os/vxWorks/osdThread.c	2012-07-31 19:04:38 +0000
+++ src/libCom/osi/os/vxWorks/osdThread.c	2013-03-28 14:15:26 +0000
@@ -449,3 +449,8 @@
     double HZ = sysClkRateGet ();
     return 1.0 / HZ;
+    return 1;
Re: [Merge] lp:~epics-core/epics-base/get-cpus into lp:epics-base mdavidsaver
Re: [Merge] lp:~epics-core/epics-base/get-cpus into lp:epics-base Andrew Johnson
Prev: PMAC Gaudiello, Phillip
Next: Re: [Merge] lp:~epics-core/epics-base/get-cpus into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
