2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Fri, 17 May 2013 22:03:24 -0000
Review: Needs Fixing
I like the idea, but before this branch is merged I would like to have (at least) agreement on how a driver (like my mrfioc2) should implement I/O Intr flow control.  My current implementation depends on the ordered execution of callbacks.
I've implemented one possible solution which adds per-priority completion callbacks for IO scans which run after all records are processed.
lp:~epics-core/epics-base/update-callback
https://code.launchpad.net/~epics-core/epics-base/parallel-cbthreads/+merge/164448
Your team EPICS Core Developers is subscribed to branch lp:~epics-core/epics-base/get-cpus.
[Merge] lp:~epics-core/epics-base/parallel-cbthreads into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads into lp:epics-base Ralph Lange
Next: Re: alarm lag Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: [Merge] lp:~epics-core/epics-base/parallel-cbthreads into lp:epics-base Ralph Lange
