See <https://jenkins.aps.anl.gov/job/epics-base-3.15/6/changes>
Changes:
[Andrew Johnson] Release notes for previous commit.
[Andrew Johnson] configure: Removed generation of xxxInclude.dbd files
Rules now expand the source DBD files directly in to the target.
Also removed the makeIncludeDbd.pl script which is no longer needed.
[...truncated 2277 lines...]
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
../CA.pm pod syntax OK.
Installing html ../../../../../html/./CA.html
rm CA.html
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ca/client/perl/O.linux-x86_64'>
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../../../.. T_A=vxWorks-ppc32 install
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ca/client/perl/O.vxWorks-ppc32'>
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ca/client/perl/O.vxWorks-ppc32'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ca/client/perl'>
make -C ioc/db/test install
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/db/test'>
perl -CSD ../../../../bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../../..
perl -CSD ../../../../bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. T_A=linux-x86_64 install
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/db/test/O.linux-x86_64'>
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../../../dbd -o xRecord.h ../xRecord.dbd
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF xRecord.d ../xRecord.c
Creating dbd file
perl -CSD ../../../../../bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../../../dbd -o arrShorthandTest.dbd xRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../../../dbd -o arrShorthandTest_registerRecordDeviceDriver.cpp ../O.Common/arrShorthandTest.dbd arrShorthandTest_registerRecordDeviceDriver <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
/usr/bin/g++ -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF arrShorthandTest_registerRecordDeviceDriver.d arrShorthandTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF arrShorthandTest.d ../arrShorthandTest.c
Creating dbd file
perl -CSD ../../../../../bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../../../dbd -o chfPluginTest.dbd xRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../../../dbd -o chfPluginTest_registerRecordDeviceDriver.cpp ../O.Common/chfPluginTest.dbd chfPluginTest_registerRecordDeviceDriver <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
/usr/bin/g++ -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF chfPluginTest_registerRecordDeviceDriver.d chfPluginTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF chfPluginTest.d ../chfPluginTest.c
Creating dbd file
perl -CSD ../../../../../bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../../../dbd -o dbChannelTest.dbd xRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl -I. -I.. -I../O.Common -I../../../../../dbd -o dbChannelTest_registerRecordDeviceDriver.cpp ../O.Common/dbChannelTest.dbd dbChannelTest_registerRecordDeviceDriver <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
/usr/bin/g++ -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF dbChannelTest_registerRecordDeviceDriver.d dbChannelTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF dbChannelTest.d ../dbChannelTest.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF dbStateTest.d ../dbStateTest.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF callbackTest.d ../callbackTest.c
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/db/test/O.linux-x86_64'>
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../xRecord.c
/usr/bin/ar -rc libxRec.a xRecord.o
/usr/bin/ranlib libxRec.a
/usr/bin/g++ -o libxRec.so.3.15 -shared -fPIC -Wl,-hlibxRec.so.3.15 -m64 xRecord.o -lpthread -lreadline -lm -lrt -ldl -lgcc
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../callbackTest.c
Installing Tcl library ../../../../../lib/linux-x86_64/libxRec.so.3.15
Installing library ../../../../../lib/linux-x86_64/libxRec.a
/usr/bin/g++ -o callbackTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -m64 callbackTest.o -lxRec -ldbCore -lca -lCom
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../dbStateTest.c
/usr/bin/g++ -o dbStateTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -m64 dbStateTest.o -lxRec -ldbCore -lca -lCom
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../dbChannelTest.c
/usr/bin/g++ -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c dbChannelTest_registerRecordDeviceDriver.cpp
/usr/bin/g++ -o dbChannelTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -m64 dbChannelTest.o dbChannelTest_registerRecordDeviceDriver.o -lxRec -ldbCore -lca -lCom
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../chfPluginTest.c
/usr/bin/g++ -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c chfPluginTest_registerRecordDeviceDriver.cpp
/usr/bin/g++ -o chfPluginTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -m64 chfPluginTest.o chfPluginTest_registerRecordDeviceDriver.o -lxRec -ldbCore -lca -lCom
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../arrShorthandTest.c
/usr/bin/g++ -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c arrShorthandTest_registerRecordDeviceDriver.cpp
/usr/bin/g++ -o arrShorthandTest -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -m64 arrShorthandTest.o arrShorthandTest_registerRecordDeviceDriver.o -lxRec -ldbCore -lca -lCom
perl -CSD ../../../../../bin/linux-x86_64/makeTestfile.pl callbackTest.t callbackTest
perl -CSD ../../../../../bin/linux-x86_64/makeTestfile.pl dbStateTest.t dbStateTest
perl -CSD ../../../../../bin/linux-x86_64/makeTestfile.pl dbChannelTest.t dbChannelTest
perl -CSD ../../../../../bin/linux-x86_64/makeTestfile.pl chfPluginTest.t chfPluginTest
perl -CSD ../../../../../bin/linux-x86_64/makeTestfile.pl arrShorthandTest.t arrShorthandTest
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/db/test/O.vxWorks-ppc32'>
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > xRecord.d ../xRecord.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > epicsRunDbTests.d ../epicsRunDbTests.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > arrShorthandTest_registerRecordDeviceDriver.d arrShorthandTest_registerRecordDeviceDriver.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > arrShorthandTest.d ../arrShorthandTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > chfPluginTest_registerRecordDeviceDriver.d chfPluginTest_registerRecordDeviceDriver.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > chfPluginTest.d ../chfPluginTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > dbChannelTest_registerRecordDeviceDriver.d dbChannelTest_registerRecordDeviceDriver.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > dbChannelTest.d ../dbChannelTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > dbStateTest.d ../dbStateTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM > callbackTest.d ../callbackTest.c
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/db/test/O.vxWorks-ppc32'>
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../xRecord.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/arppc -rc libxRec.a xRecord.o
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ranlibppc libxRec.a
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../callbackTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../dbStateTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../dbChannelTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c dbChannelTest_registerRecordDeviceDriver.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../chfPluginTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c chfPluginTest_registerRecordDeviceDriver.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../arrShorthandTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c arrShorthandTest_registerRecordDeviceDriver.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../epicsRunDbTests.c
Installing library ../../../../../lib/vxWorks-ppc32/libxRec.a
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ldppc -r -o dbTestHarness -L../../../../../lib/vxWorks-ppc32/ -L/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/powerpc-wrs-vxworks/lib callbackTest.o dbStateTest.o dbChannelTest.o dbChannelTest_registerRecordDeviceDriver.o chfPluginTest.o chfPluginTest_registerRecordDeviceDriver.o arrShorthandTest.o arrShorthandTest_registerRecordDeviceDriver.o epicsRunDbTests.o -lxRec -ldbCore -lca -lCom
/usr/local/vw/vxWorks-6.8/utilities-1.0/x86-linux2/bin/nmppc dbTestHarness > dbTestHarness.nm
perl -CSD ../../../../../bin/linux-x86_64/munch.pl -o dbTestHarness_ctdt.c dbTestHarness.nm
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -fdollars-in-identifiers -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/vxWorks -I../../../../../include -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip dbTestHarness_ctdt.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ldppc -r -T /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/tool/gnu/ldscripts/link.OUT -o dbTestHarness.munch dbTestHarness_ctdt.o dbTestHarness
Installing created executable ../../../../../bin/vxWorks-ppc32/dbTestHarness
Installing created executable ../../../../../bin/vxWorks-ppc32/dbTestHarness.munch
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/db/test'>
make -C ioc/dbtemplate/test install
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/dbtemplate/test'>
mkdir O.Common
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/dbtemplate/test/O.linux-x86_64'>
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -MM -MF dbltExpand.d ../dbltExpand.c
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/dbtemplate/test/O.linux-x86_64'>
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include -c ../dbltExpand.c
/usr/bin/g++ -o dbltExpand -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -m64 dbltExpand.o -ldbCore -lCom
cp ../msi.plt msi.t
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/dbtemplate/test/O.vxWorks-ppc32'>
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/dbtemplate/test/O.vxWorks-ppc32'>
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/ioc/dbtemplate/test'>
make -C ./std install
make[2]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/std'>
perl -CSD ../../bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
perl -CSD ../../bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/std/O.linux-x86_64'>
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aaiRecord.h ../../../src/std/rec/aaiRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aaoRecord.h ../../../src/std/rec/aaoRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aiRecord.h ../../../src/std/rec/aiRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aoRecord.h ../../../src/std/rec/aoRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aSubRecord.h ../../../src/std/rec/aSubRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o biRecord.h ../../../src/std/rec/biRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o boRecord.h ../../../src/std/rec/boRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o calcRecord.h ../../../src/std/rec/calcRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o calcoutRecord.h ../../../src/std/rec/calcoutRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o compressRecord.h ../../../src/std/rec/compressRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o dfanoutRecord.h ../../../src/std/rec/dfanoutRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o eventRecord.h ../../../src/std/rec/eventRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o fanoutRecord.h ../../../src/std/rec/fanoutRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o histogramRecord.h ../../../src/std/rec/histogramRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o longinRecord.h ../../../src/std/rec/longinRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o longoutRecord.h ../../../src/std/rec/longoutRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o mbbiRecord.h ../../../src/std/rec/mbbiRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o mbbiDirectRecord.h ../../../src/std/rec/mbbiDirectRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o mbboRecord.h ../../../src/std/rec/mbboRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o mbboDirectRecord.h ../../../src/std/rec/mbboDirectRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o permissiveRecord.h ../../../src/std/rec/permissiveRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o selRecord.h ../../../src/std/rec/selRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o seqRecord.h ../../../src/std/rec/seqRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o stateRecord.h ../../../src/std/rec/stateRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o stringinRecord.h ../../../src/std/rec/stringinRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o stringoutRecord.h ../../../src/std/rec/stringoutRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o subRecord.h ../../../src/std/rec/subRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o subArrayRecord.h ../../../src/std/rec/subArrayRecord.dbd
perl -CSD ../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o waveformRecord.h ../../../src/std/rec/waveformRecord.dbd
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF sync.d ../../../src/std/filters/sync.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF arr.d ../../../src/std/filters/arr.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF dbnd.d ../../../src/std/filters/dbnd.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF ts.d ../../../src/std/filters/ts.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF asSubRecordFunctions.d ../../../src/std/dev/asSubRecordFunctions.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devSoStdio.d ../../../src/std/dev/devSoStdio.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devTimestamp.d ../../../src/std/dev/devTimestamp.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devSoSoftCallback.d ../../../src/std/dev/devSoSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbboDirectSoftCallback.d ../../../src/std/dev/devMbboDirectSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbboSoftCallback.d ../../../src/std/dev/devMbboSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devLoSoftCallback.d ../../../src/std/dev/devLoSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devCalcoutSoftCallback.d ../../../src/std/dev/devCalcoutSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBoSoftCallback.d ../../../src/std/dev/devBoSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAoSoftCallback.d ../../../src/std/dev/devAoSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devSiSoftCallback.d ../../../src/std/dev/devSiSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbbiSoftCallback.d ../../../src/std/dev/devMbbiSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbbiDirectSoftCallback.d ../../../src/std/dev/devMbbiDirectSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devLiSoftCallback.d ../../../src/std/dev/devLiSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBiSoftCallback.d ../../../src/std/dev/devBiSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAiSoftCallback.d ../../../src/std/dev/devAiSoftCallback.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devGeneralTime.d ../../../src/std/dev/devGeneralTime.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devWfSoft.d ../../../src/std/dev/devWfSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devSoSoft.d ../../../src/std/dev/devSoSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devSiSoft.d ../../../src/std/dev/devSiSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devSASoft.d ../../../src/std/dev/devSASoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbboSoftRaw.d ../../../src/std/dev/devMbboSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbboSoft.d ../../../src/std/dev/devMbboSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbboDirectSoftRaw.d ../../../src/std/dev/devMbboDirectSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbboDirectSoft.d ../../../src/std/dev/devMbboDirectSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbbiSoftRaw.d ../../../src/std/dev/devMbbiSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbbiSoft.d ../../../src/std/dev/devMbbiSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbbiDirectSoftRaw.d ../../../src/std/dev/devMbbiDirectSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devMbbiDirectSoft.d ../../../src/std/dev/devMbbiDirectSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devLoSoft.d ../../../src/std/dev/devLoSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devLiSoft.d ../../../src/std/dev/devLiSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devHistogramSoft.d ../../../src/std/dev/devHistogramSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devEventSoft.d ../../../src/std/dev/devEventSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devCalcoutSoft.d ../../../src/std/dev/devCalcoutSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBoDbState.d ../../../src/std/dev/devBoDbState.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBoSoftRaw.d ../../../src/std/dev/devBoSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBoSoft.d ../../../src/std/dev/devBoSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBiDbState.d ../../../src/std/dev/devBiDbState.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBiSoftRaw.d ../../../src/std/dev/devBiSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devBiSoft.d ../../../src/std/dev/devBiSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAoSoftRaw.d ../../../src/std/dev/devAoSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAoSoft.d ../../../src/std/dev/devAoSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAiSoftRaw.d ../../../src/std/dev/devAiSoftRaw.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAiSoft.d ../../../src/std/dev/devAiSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAaoSoft.d ../../../src/std/dev/devAaoSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF devAaiSoft.d ../../../src/std/dev/devAaiSoft.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF waveformRecord.d ../../../src/std/rec/waveformRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF subArrayRecord.d ../../../src/std/rec/subArrayRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF subRecord.d ../../../src/std/rec/subRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF stringoutRecord.d ../../../src/std/rec/stringoutRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF stringinRecord.d ../../../src/std/rec/stringinRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF stateRecord.d ../../../src/std/rec/stateRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF seqRecord.d ../../../src/std/rec/seqRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF selRecord.d ../../../src/std/rec/selRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF permissiveRecord.d ../../../src/std/rec/permissiveRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF mbboDirectRecord.d ../../../src/std/rec/mbboDirectRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF mbboRecord.d ../../../src/std/rec/mbboRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF mbbiDirectRecord.d ../../../src/std/rec/mbbiDirectRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF mbbiRecord.d ../../../src/std/rec/mbbiRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF longoutRecord.d ../../../src/std/rec/longoutRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF longinRecord.d ../../../src/std/rec/longinRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF histogramRecord.d ../../../src/std/rec/histogramRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF fanoutRecord.d ../../../src/std/rec/fanoutRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF eventRecord.d ../../../src/std/rec/eventRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF dfanoutRecord.d ../../../src/std/rec/dfanoutRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF compressRecord.d ../../../src/std/rec/compressRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF calcoutRecord.d ../../../src/std/rec/calcoutRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF calcRecord.d ../../../src/std/rec/calcRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF boRecord.d ../../../src/std/rec/boRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF biRecord.d ../../../src/std/rec/biRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF aSubRecord.d ../../../src/std/rec/aSubRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF aoRecord.d ../../../src/std/rec/aoRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF aiRecord.d ../../../src/std/rec/aiRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF aaoRecord.d ../../../src/std/rec/aaoRecord.c
/usr/bin/gcc -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -g -Wall -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF aaiRecord.d ../../../src/std/rec/aaiRecord.c
rm -f ../O.Common/stdRecords.dbd
perl -CSD ../../../bin/linux-x86_64/makeIncludeDbd.pl aaiRecord.dbd aaoRecord.dbd aiRecord.dbd aoRecord.dbd aSubRecord.dbd biRecord.dbd boRecord.dbd calcRecord.dbd calcoutRecord.dbd compressRecord.dbd dfanoutRecord.dbd eventRecord.dbd fanoutRecord.dbd histogramRecord.dbd longinRecord.dbd longoutRecord.dbd mbbiRecord.dbd mbbiDirectRecord.dbd mbboRecord.dbd mbboDirectRecord.dbd permissiveRecord.dbd selRecord.dbd seqRecord.dbd stateRecord.dbd stringinRecord.dbd stringoutRecord.dbd subRecord.dbd subArrayRecord.dbd waveformRecord.dbd ../O.Common/stdRecords.dbd
Can't open perl script "../../../bin/linux-x86_64/makeIncludeDbd.pl": No such file or directory
make[3]: *** [../O.Common/stdRecords.dbd] Error 2
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/std/O.linux-x86_64'>
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/std'>
make[1]: *** [std.install] Error 2
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src'>
make: *** [src.install] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86_64/*.tap
Did not find any matching files.
- Build failed in Jenkins: epics-base-3.15 #7 APS Jenkins
[Merge] lp:~anj/epics-base/udf-severity into lp:epics-base noreply
<2013>
2025
2026
<2013>
2025
2026
