2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TSEL question
To: EPICS Core-Talk <[email protected]>
Date: Fri, 13 Sep 2013 16:52:52 +0200
On 13.09.2013 16:47, Ralph Lange wrote:
On 13.09.2013 01:56, Zelazny, Michael Stanley wrote:
If the db library hard codes the time field, it is reasonable for autosave to similarly hard code the time field?
Not really.
Well, maybe.
Pointing TSEL to other fields (like .VAL) is valid. The obtained value is interpreted as an event number, and the timestamp of the last occurence of that event is being used. (Requires an event system driver.)
The only way autoSaveRestore could find out if that link to .VAL was put there intentionally or if it was converted from a link to .TIME would be looking at the internal flag of the pv_link. (ppv_link->pvlMask & pvlOptTSELisTime)
I don't know ... that looks a lot like working around a dirty hack with another dirty hack.
Maybe using a new magic number for TSE would be a cleaner solution: "-3" = use timestamp of record that TSEL points to. That would make things a lot more obvious and autoSaveRestore would just work.
Dear fellow core-talkers,
Would that work? Or am I missing something?
~Ralph
Re: TSEL question Andrew Johnson
Re: TSEL question Ralph Lange
Prev: Re: TSEL question Ralph Lange
Next: Re: TSEL question Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
