2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Fri, 11 Oct 2013 16:48:38 -0000
Looks like re-init does quite work.  Remaining issues include:
> Warning: Registration already done.
>From the generated registrar code.  Only a warning.
> Warning -- iocshRegisterVariable redefining asCaDebug.
>From iocsh.c.  The lists for registered shell functions and variables need to be cleared.
> Access security is NOT enabled. Was asSetFilename specified before iocInit?
> iocBuild: asInit Failed.
The 'firstTime' flag (at least) in asDbLib.c also needs to be reset.
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown/+merge/190512
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base mdavidsaver
[Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
