2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base
To: Ralph Lange <[email protected]>
Date: Fri, 11 Oct 2013 23:10:16 -0000
re-init crashes and errors are fixed (I think).  Still leaking memory in dbReadCOM().
I've added a new test dbShutdownTest which does the complete startup and shutdown sequence twice.  This is added in src/ioc/db/test despite the fact that it depends on src/std (ie base.dbd) because I'm too lazy to create src/std/test (or similar).
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown/+merge/190512
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base.
[Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base mdavidsaver
Next: casStrmClient.cc memory leak fix Hill, Jeff
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
