2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build failed in Jenkins: epics-base-3.15 #27
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Fri, 8 Nov 2013 11:34:44 -0600
Hi Jeff,
Your commit to 3.15 broke the build for VxWorks on PowerPC, so you get to fix it.
Also please stop using the grave accent / back-tick character ` instead of an apostrophe / single quote character ' -- the two are not the same. Your commit included this change, which used the wrong one:
- * this isnt the case for some of the atomic intrinsics, and
+ * this isn`t the case for some of the atomic intrinsics, and
- Andrew
On 11/08/2013 08:08 AM, APS Jenkins wrote:
See <https://jenkins.aps.anl.gov/job/epics-base-3.15/27/changes>
Changes:
[Jeff Hill] fix for mingw gcc V3 build
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsAtomicTest.cpp
/tmp/ccur2V2S.s: Assembler messages:
/tmp/ccur2V2S.s:414: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:485: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:561: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:652: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:653: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:664: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:665: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:711: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:723: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:799: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:800: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:811: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:812: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:858: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:870: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:957: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:958: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:969: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:970: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1016: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1028: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1100: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1101: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1112: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1113: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1159: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1171: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1259: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1260: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1271: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1272: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1280: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1281: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1306: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1321: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1333: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1399: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1400: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1411: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1412: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1420: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1421: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1446: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1461: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1473: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1541: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1542: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1552: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1553: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1566: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1567: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1596: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1611: Error: Unrecognized opcode: `mfence'
/tmp/ccur2V2S.s:1623: Error: Unrecognized opcode: `mfence'
make[3]: *** [epicsAtomicTest.o] Error 1
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test/O.vxWorks-ppc604_long'>
make[2]: *** [install.vxWorks-ppc604_long] Error 2
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test'>
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src'>
make: *** [src.install] Error 2
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Build failed in Jenkins: epics-base-3.15 #27 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.15 #27 APS Jenkins
Next: Base 3.14.12.4 Release Timetable Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Build failed in Jenkins: epics-base-3.15 #28 APS Jenkins
