2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Wed, 20 Nov 2013 21:33:44 -0000
This looks very similar to the CONTAINER macro from dbDefs.h, although slightly cleaner to use since the C++ compiler can deduce both types from the pointer-to-member argument. Is this as type-safe as the GNU version of CONTAINER, which checks that the member's data type matches the pointer? I note that CONTAINER works for C code, whereas this is pure C++.
My main concern is getting the name right; since we're already using the word Container would it make sense to use that instead of Enclosure?
Also, should we move the CONTAINER macro into this header (with guards to allow it to be included from C code)?
https://code.launchpad.net/~johill-lanl/epics-base/epics-base-enclosure-of/+merge/196010
Your team EPICS Core Developers is requested to review the proposed merge of lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base.
[Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Prev: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 20 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
