2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15 #30
To: [email protected]
Date: Wed, 20 Nov 2013 18:07:44 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15/30/changes>
Changes:
[Andrew Johnson] Clean up array subscript has type ‘char’ warnings.
[...truncated 1732 lines...]
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsThreadTest.d  ../epicsThreadTest.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsTimeTest.d  ../epicsTimeTest.cpp
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsStringTest.d  ../epicsStringTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsSockResolveTest.d  ../epicsSockResolveTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsStdlibTest.d  ../epicsStdlibTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsStdioTest.d  ../epicsStdioTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsErrlogTest.d  ../epicsErrlogTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsEllTest.d  ../epicsEllTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsMathTest.d  ../epicsMathTest.c
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsAlgorithmTest.d  ../epicsAlgorithmTest.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsCalcTest.d  ../epicsCalcTest.cpp
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsTypesTest.d  ../epicsTypesTest.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -MM -MF epicsUnitTestTest.d  ../epicsUnitTestTest.c
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test/O.linux-x86_64'>
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test/O.linux-x86_64'>
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsUnitTestTest.c
/usr/bin/g++ -o epicsUnitTestTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsUnitTestTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsTypesTest.c
/usr/bin/g++ -o epicsTypesTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsTypesTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsCalcTest.cpp
/usr/bin/g++ -o epicsCalcTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsCalcTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsAlgorithmTest.cpp
/usr/bin/g++ -o epicsAlgorithmTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsAlgorithmTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsMathTest.c
/usr/bin/g++ -o epicsMathTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsMathTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsEllTest.c
/usr/bin/g++ -o epicsEllTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsEllTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsErrlogTest.c
/usr/bin/g++ -o epicsErrlogTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsErrlogTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsStdioTest.c
/usr/bin/g++ -o epicsStdioTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsStdioTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsStdlibTest.c
/usr/bin/g++ -o epicsStdlibTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsStdlibTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsSockResolveTest.c
/usr/bin/g++ -o epicsSockResolveTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsSockResolveTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsStringTest.c
/usr/bin/g++ -o epicsStringTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsStringTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsTimeTest.cpp
/usr/bin/g++ -o epicsTimeTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsTimeTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsThreadTest.cpp
/usr/bin/g++ -o epicsThreadTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsThreadTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsThreadOnceTest.c
/usr/bin/g++ -o epicsThreadOnceTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsThreadOnceTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsThreadPriorityTest.cpp
/usr/bin/g++ -o epicsThreadPriorityTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsThreadPriorityTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsThreadPrivateTest.cpp
/usr/bin/g++ -o epicsThreadPrivateTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsThreadPrivateTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsThreadHooksTest.c
/usr/bin/g++ -o epicsThreadHooksTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsThreadHooksTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsExitTest.c
/usr/bin/g++ -o epicsExitTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsExitTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsTimerTest.cpp
/usr/bin/g++ -o epicsTimerTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsTimerTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../ringPointerTest.c
/usr/bin/g++ -o ringPointerTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               ringPointerTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../ringBytesTest.c
/usr/bin/g++ -o ringBytesTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               ringBytesTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsEventTest.cpp
/usr/bin/g++ -o epicsEventTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsEventTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsMutexTest.cpp
/usr/bin/g++ -o epicsMutexTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsMutexTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsSpinTest.c
/usr/bin/g++ -o epicsSpinTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsSpinTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsAtomicTest.cpp
/usr/bin/g++ -o epicsAtomicTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsAtomicTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsExceptionTest.cpp
/usr/bin/g++ -o epicsExceptionTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsExceptionTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../macEnvExpandTest.c
/usr/bin/g++ -o macEnvExpandTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               macEnvExpandTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../macLibTest.c
/usr/bin/g++ -o macLibTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               macLibTest.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../taskwdTest.c
/usr/bin/g++ -o taskwdTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               taskwdTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../blockingSockTest.cpp
/usr/bin/g++ -o blockingSockTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               blockingSockTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsMessageQueueTest.cpp
/usr/bin/g++ -o epicsMessageQueueTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsMessageQueueTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsThreadPerform.cpp
/usr/bin/g++ -o epicsThreadPerform  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsThreadPerform.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsMaxThreads.c
/usr/bin/g++ -o epicsMaxThreads  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsMaxThreads.o    -lCom
/usr/bin/gcc  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../buckTest.c
/usr/bin/g++ -o buckTest  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               buckTest.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../epicsAtomicPerform.cpp
/usr/bin/g++ -o epicsAtomicPerform  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               epicsAtomicPerform.o    -lCom
/usr/bin/g++  -D_POSIX_C_SOURCE=200112L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include        -c ../cvtFastPerform.cpp
/usr/bin/g++ -o cvtFastPerform  -L<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64> -Wl,-rpath,<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/lib/linux-x86_64>       -m64               cvtFastPerform.o    -lCom
cp ../epicsUnitTestTest.plt epicsUnitTestTest.t
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsTypesTest.t epicsTypesTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsCalcTest.t epicsCalcTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsAlgorithmTest.t epicsAlgorithmTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsMathTest.t epicsMathTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsEllTest.t epicsEllTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsErrlogTest.t epicsErrlogTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsStdioTest.t epicsStdioTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsStdlibTest.t epicsStdlibTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsSockResolveTest.t epicsSockResolveTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsStringTest.t epicsStringTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsTimeTest.t epicsTimeTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsThreadTest.t epicsThreadTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsThreadOnceTest.t epicsThreadOnceTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsThreadPriorityTest.t epicsThreadPriorityTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsThreadPrivateTest.t epicsThreadPrivateTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsThreadHooksTest.t epicsThreadHooksTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsExitTest.t epicsExitTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsTimerTest.t epicsTimerTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl ringPointerTest.t ringPointerTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl ringBytesTest.t ringBytesTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsEventTest.t epicsEventTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsMutexTest.t epicsMutexTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsSpinTest.t epicsSpinTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsAtomicTest.t epicsAtomicTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsExceptionTest.t epicsExceptionTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl macEnvExpandTest.t macEnvExpandTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl macLibTest.t macLibTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl taskwdTest.t taskwdTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl blockingSockTest.t blockingSockTest
perl -CSD ../../../../bin/linux-x86_64/makeTestfile.pl epicsMessageQueueTest.t epicsMessageQueueTest
make -C O.vxWorks-ppc604_long -f ../Makefile TOP=../../../.. T_A=vxWorks-ppc604_long install
make[3]: Entering directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test/O.vxWorks-ppc604_long'>
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > cvtFastPerform.d  ../cvtFastPerform.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsAtomicPerform.d  ../epicsAtomicPerform.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > buckTest.d  ../buckTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsMaxThreads.d  ../epicsMaxThreads.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsThreadPerform.d  ../epicsThreadPerform.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsRunLibComTests.d  ../epicsRunLibComTests.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsMessageQueueTest.d  ../epicsMessageQueueTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > blockingSockTest.d  ../blockingSockTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > taskwdTest.d  ../taskwdTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > macLibTest.d  ../macLibTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > macEnvExpandTest.d  ../macEnvExpandTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsExceptionTest.d  ../epicsExceptionTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsAtomicTest.d  ../epicsAtomicTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsSpinTest.d  ../epicsSpinTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsMutexTest.d  ../epicsMutexTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsEventTest.d  ../epicsEventTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > ringBytesTest.d  ../ringBytesTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > ringPointerTest.d  ../ringPointerTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsTimerTest.d  ../epicsTimerTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsExitTest.d  ../epicsExitTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsThreadHooksTest.d  ../epicsThreadHooksTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsThreadPrivateTest.d  ../epicsThreadPrivateTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsThreadPriorityTest.d  ../epicsThreadPriorityTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsThreadOnceTest.d  ../epicsThreadOnceTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsThreadTest.d  ../epicsThreadTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsTimeTest.d  ../epicsTimeTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsStringTest.d  ../epicsStringTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsSockResolveTest.d  ../epicsSockResolveTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsStdlibTest.d  ../epicsStdlibTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsStdioTest.d  ../epicsStdioTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsErrlogTest.d  ../epicsErrlogTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsEllTest.d  ../epicsEllTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsMathTest.d  ../epicsMathTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsAlgorithmTest.d  ../epicsAlgorithmTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsCalcTest.d  ../epicsCalcTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -MM > epicsTypesTest.d  ../epicsTypesTest.c
make[3]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test/O.vxWorks-ppc604_long'>
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsTypesTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsCalcTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsAlgorithmTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsMathTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsEllTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsErrlogTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsStdioTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsStdlibTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsSockResolveTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsStringTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsTimeTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsThreadTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsThreadOnceTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsThreadPriorityTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsThreadPrivateTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsThreadHooksTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsExitTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsTimerTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../ringPointerTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../ringBytesTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsEventTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsMutexTest.cpp
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsSpinTest.c
/usr/local/vw/tornado22-ppc/host/x86-linux/bin/ccppc            -DCPU=PPC604  -DvxWorks=vxWorks -include /usr/local/vw/tornado22-ppc/target/h/vxWorks.h    -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include       -I/usr/local/vw/tornado22-ppc/target/h -c ../epicsAtomicTest.cpp
/tmp/cc8Lvpqi.s: Assembler messages:
/tmp/cc8Lvpqi.s:414: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:485: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:561: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:652: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:653: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:664: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:665: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:711: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:723: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:799: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:800: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:811: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:812: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:858: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:870: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:957: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:958: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:969: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:970: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1016: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1028: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1100: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1101: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1112: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1113: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1159: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1171: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1259: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1260: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1271: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1272: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1280: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1281: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1306: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1321: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1333: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1399: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1400: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1411: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1412: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1420: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1421: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1446: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1461: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1473: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1541: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1542: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1552: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1553: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1566: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1567: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1596: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1611: Error: Unrecognized opcode: `mfence'
/tmp/cc8Lvpqi.s:1623: Error: Unrecognized opcode: `mfence'
make[3]: *** [epicsAtomicTest.o] Error 1
make[2]: *** [install.vxWorks-ppc604_long] Error 2
make[2]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src/libCom/test'>
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory `<https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/src'>
make: *** [src.install] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86_64/*.tap
Did not find any matching files.
Jenkins build is back to normal : epics-base-3.15 #31 APS Jenkins
Build failed in Jenkins: epics-base-3.15 #29 APS Jenkins
Prev: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Next: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-3.15 #29 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15 #31 APS Jenkins
ANJ, 21 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
