2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Thu, 21 Nov 2013 14:15:36 -0000
On 11/20/13 20:37, Jeff Hill wrote:
> The offsetof() is implemented as a macro, and therefore less suitable
for use in templates.
While offsetof() can be implemented as a macro, with GCC it is a builtin
with additional checking.  It is not specified to work on C++ classes.
Using reinterpret_cast<> to bypass these checks seems questionable to
me.  I'm worried that this might involve Undefined Behavior.
> This implementation should work just fine with user defined types, and
I believe that the regression test should be testing that situation.
Your regression test don't cover the cases which I am worried about.
Please add additional unit tests covering inheritance situations
(single, multiple, and virtual) or explicitly document that
"enclosureOf" is not supported in these cases.
https://code.launchpad.net/~johill-lanl/epics-base/epics-base-enclosure-of/+merge/196010
Your team EPICS Core Developers is requested to review the proposed merge of lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base.
Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Prev: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Next: Jenkins build is back to normal : epics-base-3.15 #31 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
ANJ, 21 Nov 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
