2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sel and seq records
To: Dirk Zimoch <[email protected]>, EPICS core-talk <[email protected]>
Date: Mon, 2 Dec 2013 14:07:46 -0600
Hi Dirk,
On 11/27/2013 07:09 AM, Dirk Zimoch wrote:
I have added pp(TRUE) to some fields, so that the behavior is similar to
the calc record. The following fields are affected:
sel: SELM, SELN
seq: SELM, SELN, DO1, DO2, ... DOA
I don't want to make this kind of change to record behaviour in a bug-fix release (3.14.12.4), although I will consider them for the 3.15 branch.
The seq record only has one field marked as pp(TRUE), the VAL field, and the prompt text for that field is "Used to trigger", so I suspect the implicit pp(FALSE) setting on the other fields was a deliberate design decision by the author. I'm currently inclined to change the sel record but not the seq, but would appreciate comments from anyone else about this idea (which makes the two behave differently so I'm not really convinced that's right either).
The disadvantage of making fields pp(TRUE) is that a client then has no choice about processing the record, whereas for a pp(FALSE) field a client can always follow up with a put to the PROC field (there's a feature which display managers haven't implemented yet AFAIK). A database designer can also insert an ao record in front of the relevant fields of the seq record with a PP or NPP output link to change the behaviour one way or the other, so there are workarounds to a field having the wrong pp() setting.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Prev: Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] lp:~epics-core/epics-base/postdbrprop into lp:epics-base noreply
ANJ, 04 Dec 2013 · Home · News · About · Talk · Base · Modules · Extensions ·
