2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Thu, 10 Jul 2014 23:09:17 -0000
On 07/10/2014 05:40 PM, mdavidsaver wrote:
> Function names changed as requested.
You misunderstood a couple of my suggestions; I meant dbShutdownTest to
look like this:
    testdbReadDatabase("xRecord.db", NULL, NULL);
    testIocInitOk();
    epicsThreadMap(findCommonThread);
    checkCommonThreads();
    testIocShutdownOk();
    testdbCleanup();
The ...Ok() functions should incorporate calls to testOk() so the user
doesn't have to remember whether she needs to invert the result or not,
and should also use explicit text such as "IOC Initialized".
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown2/+merge/224213
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown2 into lp:epics-base mdavidsaver
ANJ, 10 Jul 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
