2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Array data in db files?
To: <[email protected]>
Date: Sun, 24 Aug 2014 21:42:44 +0200
Am Montag, 18. August 2014, 10:46:57 schrieb Michael Davidsaver:
> One of changes I'm considering (after the linking/locking work) is to
> re-write the DBD file parser.
> The idea would be to parse into an intermediate structure which would be
> more general than dbStatic.  This would define points in the syntax for
> future expansion, and avoid some of the chicken and egg problems of the
> present code.
This reminds me of the following idea I had some years ago, which might be
similar or not to what you have in mind.
The db/dbd syntax can be generalized to a very simple syntax that basically
recognizes one kind of item:
  item ::= keyword "(" arg "," ... ")" [ "{" item ... "}" ]
(where 'arg' is defined by the lexical syntax as a quoted or unquoted string,
and 'keyword' is a sequence of lower case letters). A lookup-table defines the
mapping of keywords to functions of type
  void parse_item(database *db, arg_list *args, item_list *items);
This function then checks that the number and types of its arguments and sub-
items are correct, produces the final output and adds it to the database.
I am fully aware that there are many details missing in this picture, this is
merely a rough sketch of the idea, not a full design spec.
The main point is that the syntax is now easily extensible by adding a new
keyword and the corresponding function in the table. Unknown keywords
(together with the item they introduce) are ignored (or optionally give
warning), so that future extensions never break existing parsers.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Array data in db files? Michael Davidsaver
Array data in db files? Ralph Lange
Prev: Re: Array data in db files? Michael Davidsaver
Next: Re: ePID deadband on output Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Array data in db files? Michael Davidsaver
ANJ, 25 Aug 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
