2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ePID deadband on output
To: Bruce Hill <[email protected]>
Cc: Core-Talk <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Aug 2014 19:41:32 +0000
Would it make sense to implement both modes, one IIR filter and one time-bound deadband? The IIR approach makes sense: If the error gets small enough, turn off the control, and only turn it on again until the error increases too much. The time-bound approach would deal with the case where the user wants control turned off after N seconds, as long as it's been within the deadband that long (which might be more deterministic in some cases).
Cheers,
Matt
On Aug 26, 2014, at 3:17 PM, Bruce Hill <[email protected]> wrote:
> Hi Matt,
> I used discrete records for this instead of modifying the epid record.
> If you have time to look into implementing this in epid, that would be great.
> Thanks!
> - Bruce
> On 8/26/2014 7:38 AM, Pearson, Matthew R. wrote:
>> Hi,
>> It sounds like it would work for my application.
>> If there is no ePID code, I would be willing to implement it in the ePID.
>> Cheers,
>> Matt
>> On Aug 26, 2014, at 8:07 AM, "Dalesio, Leo" <[email protected]> wrote:
>>> Hi Bruce.
>>> Did you make this part of the ePID record? I have not looked at that code for a while. Did you modify the record? Could you send the code? I think it would be a good modification. There are a number of situations where motors should not be dithering.
>>> Bob
Re: ePID deadband on output Bruce Hill
Re: ePID deadband on output Benjamin Franksen
RE: ePID deadband on output Mark Rivers
RE: ePID deadband on output Dalesio, Leo
Re: ePID deadband on output Pearson, Matthew R.
Re: ePID deadband on output fong
Prev: Re: ePID deadband on output Bruce Hill
Next: Re: ePID deadband on output Bruce Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Aug 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
