2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building 3.15 latest with -j on linux-x86 and vxWorks
To: "'Andrew Johnson'" <[email protected]>, "'Core-Talk'" <[email protected]>
Date: Mon, 10 Nov 2014 19:37:17 +0000
Hi Andrew,
I downloaded the latest 3.15 using bzr today.
I first tried a parallel make for just “host” on linux-x86:
corvette:local/epics/base-3.15.0>make -sj distclean
corvette:local/epics/base-3.15.0>make -sj host
epicsTempFile.o: In function `epicsTempName':
/usr/local/epics/base-3.15.0/src/libCom/O.linux-x86/../../../src/libCom/osi/os/posix/epicsTempFile.cpp:23: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
In file included from ../../../src/libCom/osi/os/Linux/osdFindAddr.c:10:0:
../../../src/libCom/osi/os/posix/osdElfFindAddr.c: In function 'epicsFindAddr':
../../../src/libCom/osi/os/posix/osdElfFindAddr.c:642:24: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
dbdExpand.pl: Can't find file 'menuAlarmSevr.dbd'
  while reading 'menuAlarmSevr.dbd' to create '../O.Common/menuGlobal.dbd.d'
  Your Makefile may need this dependency rule:
    menuGlobal.dbd$(DEP): $(COMMON_DIR)/menuAlarmSevr.dbd
../../../../../../src/ca/legacy/pcas/generic/casDGClient.cc: In member function 'caStatus casDGClient::searchFailResponse(const caHdrLargeArray*)':
../../../../../../src/ca/legacy/pcas/generic/casDGClient.cc:351:7: warning: variable 'status' set but not used [-Wunused-but-set-variable]
I am not sure if the dbdExpand.pl message is an error, or just a warning?
However, when I try to cross-compile for vxWorks when doing the build I still get these errors:
make[3]: *** No rule to make target `../../../bin/linux-x86/e_flex', needed by `asLib_lex.c'.  Stop.
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [install.vxWorks-68040] Error 2
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [install.vxWorks-ppc604_long] Error 2
make[2]: *** [install.vxWorks-ppc603_long] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
If I first do
make –sj host
and then
make –sj
it works, because the host tools are built in the first pass.
Sent: Monday, November 03, 2014 6:24 PM
To: 'Andrew Johnson'; 'Core-Talk'
Subject: Problem building 3.15 latest with -j on linux-x86 and vxWorks
Hi Andrew,
I am having problems building 3.15 latest (revision 12577) with the –j option.
It works OK with linux-x86_64 which does not do cross-compiling for vxWorks on my system:
corvette:local/epics/base-3.15.0>make -sj clean uninstall
corvette:local/epics/base-3.15.0>date ; make -sj ; date
Mon Nov  3 18:17:49 CST 2014
/usr/local/epics/base-3.15.0/src/libCom/O.linux-x86_64/../../../src/libCom/osi/os/posix/epicsTempFile.cpp:23: warning: the use of `tmpnam' is dangerous, better use `mkstemp'
../Cap5.xs: In function 'CA_replace_access_rights_event':
../Cap5.xs:549:21: warning: initialization from incompatible pointer type [enabled by default]
Mon Nov  3 18:18:10 CST 2014
So it took 21 seconds to build base.
However, when I build on linux-x86, which does cross-compile 3 vxWorks archs it fails:
Mon Nov  3 18:20:13 CST 2014
Mon Nov  3 18:20:23 CST 2014
Problem building 3.15 latest with -j on linux-x86 and vxWorks Mark Rivers
Prev: 3.15.1 Release Timetable Andrew Johnson
Next: Jenkins build became unstable: epics-base-3.15 #135 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem building 3.15 latest with -j on linux-x86 and vxWorks Mark Rivers
Next: Jenkins build became unstable: epics-base-3.15 #132 APS Jenkins
ANJ, 10 Nov 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
