2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base 3.14.12.5-pre1 Available
To: <[email protected]>
Date: Mon, 9 Mar 2015 15:55:37 -0500
Hi Ben,
On 03/07/2015 06:33 PM, Benjamin Franksen wrote:
> Interesting. I am not sure I completely understand your remark that
> "cfg/RULES* files are only included by Makefiles that are compiling code".
> Does that imply cfg/RULES* are only included (via $(TOP)/configure/RULES) if
> T_A is defined?
Yes, cfg/RULES* files are included by Base/configure/RULES_FILE_TYPE
which is included by Base/configure/RULES_BUILD which gets pulled in by
Base/configure/RULES only when T_A is defined.
The new cfg/DIR_RULES* files get included when T_A is not defined,
either by Base/configure/RULES_ARCHS or Base/configure/RULES_DIRS.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
    against your wishes, and doesn't give you the key, they're
    not doing it for your benefit.
Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
Base 3.14.12.5-pre1 Available Andrew Johnson
Re: Base 3.14.12.5-pre1 Available Andrew Johnson
Prev: Re: mkmf.pl broken in 3.15? Johnson, Andrew N.
Next: Build failed in Jenkins: epics-base-3.15-mac #15 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
Next: Re: Base 3.14.12.5-pre1 Available Benjamin Franksen
