2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-mac #43
To: [email protected]
Date: Tue, 24 Mar 2015 09:28:08 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-mac/43/changes>
Changes:
[Janet Anderson] Set version number to R3.14.12.5.
Started by upstream project "epics-base-3.14" build number 130
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-mac/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-mac/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-mac/ws/> returned 0. Command output: "12578 [email protected]
" stderr: ""
[epics-base-3.14-mac] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.14-mac] $ bzr pull --overwrite bzr+ssh://bazaar.launchpad.net/%2Bbranch/epics-base/3.14/
 M  configure/CONFIG_BASE_VERSION
All changes applied successfully.
Now on revision 12579.
1 tag(s) updated.
[epics-base-3.14-mac] $ bzr revert
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.14-mac/ws/> returned 0. Command output: "12579 [email protected]
" stderr: ""
[epics-base-3.14-mac] $ bzr log -v -r revid:[email protected]:[email protected] --long --show-ids
Getting local revision...
" stderr: ""
RevisionState revno:12579 revid:[email protected]
[epics-base-3.14-mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/hudson3146920429015910253.sh
+ make darwin-x86
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./configure darwin-x86
perl ../src/tools/makeMakefile.pl O.darwin-x86 ../..
mkdir O.Common
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86
make[2]: Nothing to be done for `all'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./src darwin-x86
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./tools darwin-x86
perl ../../src/tools/makeMakefile.pl O.darwin-x86 ../../..
mkdir O.Common
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing script ../../../bin/darwin-x86/convertRelease.pl
mkdir ../../../bin
mkdir ../../../bin/darwin-x86
Installing script ../../../bin/darwin-x86/cvsclean.pl
Installing script ../../../bin/darwin-x86/dos2unix.pl
Installing script ../../../bin/darwin-x86/expandVars.pl
Installing script ../../../bin/darwin-x86/filterWarnings.pl
Installing script ../../../bin/darwin-x86/fullPathName.pl
Installing script ../../../bin/darwin-x86/installEpics.pl
Installing script ../../../bin/darwin-x86/makeIncludeDbd.pl
Installing script ../../../bin/darwin-x86/makeMakefile.pl
Installing script ../../../bin/darwin-x86/makeTestfile.pl
Installing script ../../../bin/darwin-x86/mkmf.pl
Installing script ../../../bin/darwin-x86/munch.pl
Installing script ../../../bin/darwin-x86/replaceVAR.pl
Installing script ../../../bin/darwin-x86/useManifestTool.pl
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./makeBaseApp darwin-x86
perl ../../bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../..
mkdir O.Common
Installing script ../../../bin/darwin-x86/makeBaseApp.pl
Installing ../../../templates/makeBaseApp/top/Makefile
mkdir ../../../templates
mkdir ../../../templates/makeBaseApp
mkdir ../../../templates/makeBaseApp/top
Installing ../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../templates/makeBaseApp/top/configure
Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../templates/makeBaseApp/top/configure/RULES
Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP
Installing ../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../templates/makeBaseApp/top/supportApp
Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
Installing ../../../templates/makeBaseApp/top/iocApp/Makefile
mkdir ../../../templates/makeBaseApp/top/iocApp
Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile
mkdir ../../../templates/makeBaseApp/top/iocApp/Db
Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile
mkdir ../../../templates/makeBaseApp/top/iocApp/src
Installing ../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp
Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleApp
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleApp/Db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions
Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleApp/src
Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt
Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st
Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp
Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd
Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleBoot
Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks
Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common
mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks
Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile
mkdir ../../../templates/makeBaseApp/top/caClientApp
Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c
Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c
Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile
mkdir ../../../templates/makeBaseApp/top/caServerApp
Installing ../../../templates/makeBaseApp/top/caServerApp/README
Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h
Installing ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl
Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc
Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile
mkdir ../../../templates/makeBaseApp/top/iocBoot
Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks
Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./makeBaseExt darwin-x86
mkdir O.Common
Installing script ../../../bin/darwin-x86/makeBaseExt.pl
Installing ../../../templates/makeBaseExt/top/Makefile
mkdir ../../../templates/makeBaseExt
mkdir ../../../templates/makeBaseExt/top
Installing ../../../templates/makeBaseExt/top/README
Installing ../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../templates/makeBaseExt/top/configure
Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE
Installing ../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386
mkdir ../../../templates/makeBaseExt/top/configure/os
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../templates/makeBaseExt/top/src
Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../templates/makeBaseExt/top/exampleExt
Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../templates/makeBaseExt/top/simpleExt
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./libCom darwin-x86
mkdir O.Common
perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG_BASE_VERSION ../O.Common
Variable missing from ../../../configure/CONFIG_BASE_VERSION at ../../../src/libCom/misc/makeEpicsVersion.pl line 37.
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
make[3]: *** [../O.Common/epicsVersion.h] Error 255
make[2]: *** [darwin-x86] Error 2
make[1]: *** [libCom.darwin-x86] Error 2
make: *** [src.darwin-x86] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Did not find any matching files.
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.14-mac #44 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.14-vx55 #80 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-linux32 #83 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.14-vx55 #81 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.14-mac #44 APS Jenkins
