2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Raising the 80 char limit on INP/OUT strings?
To: EPICS Core-Talk <[email protected]>
Date: Wed, 08 Apr 2015 14:02:43 +0200
Michael just showed me that this limitation went away in 3.16 as part of the new link parser code.
Good!
So - what to do with 3.15?
(I'm afraid waiting for 3.16 is not short-term enough.)
I would opt for the simple version: make the buffer statically length 256.
~Ralph
On 08/04/2015 10:46, Ralph Lange wrote:
Dear all,
I have a request to raise the current limit of 80 chars on INP/OUT fields.
Some device supports (e.g. OPC, SNMP) use device-side names in that field to map signals, and names in those systems might be long.
Internally, these strings are stored in their natural length - it is just the code in dbPutString() (dbStaticLib.c 2029ff.) that sets and enforces the limit. However, having a limit makes sense to detect runaway strings (missing quotes etc.)
I see two easy feasible options:
  1. Statically raise the limit (e.g. to 256).
  2. Add an IOC variable, make the buffer static, and alloc it once (in the function).
What do you think?
Cheers,
~Ralph
Re: Raising the 80 char limit on INP/OUT strings? Michael Davidsaver
Raising the 80 char limit on INP/OUT strings? Ralph Lange
Prev: Raising the 80 char limit on INP/OUT strings? Ralph Lange
Next: Re: Raising the 80 char limit on INP/OUT strings? Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
