See <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/22/changes>
Changes:
[Andrew Johnson] Merged fix from 3.15 branch, up to revno 12671
[...truncated 1820 lines...]
Installing dbd file ../../../dbd/dfanoutRecord.dbd
Installing dbd file ../../../dbd/eventRecord.dbd
Installing dbd file ../../../dbd/fanoutRecord.dbd
Installing dbd file ../../../dbd/histogramRecord.dbd
Installing dbd file ../../../dbd/longinRecord.dbd
Installing dbd file ../../../dbd/longoutRecord.dbd
Installing dbd file ../../../dbd/lsiRecord.dbd
Installing dbd file ../../../dbd/lsoRecord.dbd
Installing dbd file ../../../dbd/mbbiRecord.dbd
Installing dbd file ../../../dbd/mbbiDirectRecord.dbd
Installing dbd file ../../../dbd/mbboRecord.dbd
Installing dbd file ../../../dbd/mbboDirectRecord.dbd
Installing dbd file ../../../dbd/permissiveRecord.dbd
Installing dbd file ../../../dbd/printfRecord.dbd
Installing dbd file ../../../dbd/selRecord.dbd
Installing dbd file ../../../dbd/seqRecord.dbd
Installing dbd file ../../../dbd/stateRecord.dbd
Installing dbd file ../../../dbd/stringinRecord.dbd
Installing dbd file ../../../dbd/stringoutRecord.dbd
Installing dbd file ../../../dbd/subRecord.dbd
Installing dbd file ../../../dbd/subArrayRecord.dbd
Installing created dbd file ../../../dbd/waveformRecord.dbd
Installing ../../../db/softIocExit.db
mkdir ../../../db
Installing generated generic include file ../../../include/aaiRecord.h
Installing generated generic include file ../../../include/aaoRecord.h
Installing generated generic include file ../../../include/aiRecord.h
Installing generated generic include file ../../../include/aoRecord.h
Installing generated generic include file ../../../include/aSubRecord.h
Installing generated generic include file ../../../include/biRecord.h
Installing generated generic include file ../../../include/boRecord.h
Installing generated generic include file ../../../include/calcRecord.h
Installing generated generic include file ../../../include/calcoutRecord.h
Installing generated generic include file ../../../include/compressRecord.h
Installing generated generic include file ../../../include/dfanoutRecord.h
Installing generated generic include file ../../../include/eventRecord.h
Installing generated generic include file ../../../include/fanoutRecord.h
Installing generated generic include file ../../../include/histogramRecord.h
Installing generated generic include file ../../../include/longinRecord.h
Installing generated generic include file ../../../include/longoutRecord.h
Installing generated generic include file ../../../include/lsiRecord.h
Installing generated generic include file ../../../include/lsoRecord.h
Installing generated generic include file ../../../include/mbbiRecord.h
Installing generated generic include file ../../../include/mbbiDirectRecord.h
Installing generated generic include file ../../../include/mbboRecord.h
Installing generated generic include file ../../../include/mbboDirectRecord.h
Installing generated generic include file ../../../include/permissiveRecord.h
Installing generated generic include file ../../../include/printfRecord.h
Installing generated generic include file ../../../include/selRecord.h
Installing generated generic include file ../../../include/seqRecord.h
Installing generated generic include file ../../../include/stateRecord.h
Installing generated generic include file ../../../include/stringinRecord.h
Installing generated generic include file ../../../include/stringoutRecord.h
Installing generated generic include file ../../../include/subRecord.h
Installing generated generic include file ../../../include/subArrayRecord.h
Installing generated generic include file ../../../include/waveformRecord.h
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o aaiRecord.obj -c ../../../src/std/rec/aaiRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o aaoRecord.obj -c ../../../src/std/rec/aaoRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o aiRecord.obj -c ../../../src/std/rec/aiRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o aoRecord.obj -c ../../../src/std/rec/aoRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o aSubRecord.obj -c ../../../src/std/rec/aSubRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o biRecord.obj -c ../../../src/std/rec/biRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o boRecord.obj -c ../../../src/std/rec/boRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o calcRecord.obj -c ../../../src/std/rec/calcRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o calcoutRecord.obj -c ../../../src/std/rec/calcoutRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o compressRecord.obj -c ../../../src/std/rec/compressRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o dfanoutRecord.obj -c ../../../src/std/rec/dfanoutRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o eventRecord.obj -c ../../../src/std/rec/eventRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o fanoutRecord.obj -c ../../../src/std/rec/fanoutRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o histogramRecord.obj -c ../../../src/std/rec/histogramRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o longinRecord.obj -c ../../../src/std/rec/longinRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o longoutRecord.obj -c ../../../src/std/rec/longoutRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o lsiRecord.obj -c ../../../src/std/rec/lsiRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o lsoRecord.obj -c ../../../src/std/rec/lsoRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o mbbiRecord.obj -c ../../../src/std/rec/mbbiRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o mbbiDirectRecord.obj -c ../../../src/std/rec/mbbiDirectRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o mbboRecord.obj -c ../../../src/std/rec/mbboRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o mbboDirectRecord.obj -c ../../../src/std/rec/mbboDirectRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o permissiveRecord.obj -c ../../../src/std/rec/permissiveRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o printfRecord.obj -c ../../../src/std/rec/printfRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o selRecord.obj -c ../../../src/std/rec/selRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o seqRecord.obj -c ../../../src/std/rec/seqRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o stateRecord.obj -c ../../../src/std/rec/stateRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o stringinRecord.obj -c ../../../src/std/rec/stringinRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o stringoutRecord.obj -c ../../../src/std/rec/stringoutRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o subRecord.obj -c ../../../src/std/rec/subRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o subArrayRecord.obj -c ../../../src/std/rec/subArrayRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o waveformRecord.obj -c ../../../src/std/rec/waveformRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAaiSoft.obj -c ../../../src/std/dev/devAaiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAaoSoft.obj -c ../../../src/std/dev/devAaoSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAiSoft.obj -c ../../../src/std/dev/devAiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAiSoftRaw.obj -c ../../../src/std/dev/devAiSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAoSoft.obj -c ../../../src/std/dev/devAoSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAoSoftRaw.obj -c ../../../src/std/dev/devAoSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBiSoft.obj -c ../../../src/std/dev/devBiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBiSoftRaw.obj -c ../../../src/std/dev/devBiSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBiDbState.obj -c ../../../src/std/dev/devBiDbState.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBoSoft.obj -c ../../../src/std/dev/devBoSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBoSoftRaw.obj -c ../../../src/std/dev/devBoSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBoDbState.obj -c ../../../src/std/dev/devBoDbState.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devCalcoutSoft.obj -c ../../../src/std/dev/devCalcoutSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devEventSoft.obj -c ../../../src/std/dev/devEventSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devHistogramSoft.obj -c ../../../src/std/dev/devHistogramSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLiSoft.obj -c ../../../src/std/dev/devLiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLoSoft.obj -c ../../../src/std/dev/devLoSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLsiSoft.obj -c ../../../src/std/dev/devLsiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLsoSoft.obj -c ../../../src/std/dev/devLsoSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbbiDirectSoft.obj -c ../../../src/std/dev/devMbbiDirectSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbbiDirectSoftRaw.obj -c ../../../src/std/dev/devMbbiDirectSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbbiSoft.obj -c ../../../src/std/dev/devMbbiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbbiSoftRaw.obj -c ../../../src/std/dev/devMbbiSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbboDirectSoft.obj -c ../../../src/std/dev/devMbboDirectSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbboDirectSoftRaw.obj -c ../../../src/std/dev/devMbboDirectSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbboSoft.obj -c ../../../src/std/dev/devMbboSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbboSoftRaw.obj -c ../../../src/std/dev/devMbboSoftRaw.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devPrintfSoft.obj -c ../../../src/std/dev/devPrintfSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devSASoft.obj -c ../../../src/std/dev/devSASoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devSiSoft.obj -c ../../../src/std/dev/devSiSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devSoSoft.obj -c ../../../src/std/dev/devSoSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devWfSoft.obj -c ../../../src/std/dev/devWfSoft.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devGeneralTime.obj -c ../../../src/std/dev/devGeneralTime.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAiSoftCallback.obj -c ../../../src/std/dev/devAiSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBiSoftCallback.obj -c ../../../src/std/dev/devBiSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLiSoftCallback.obj -c ../../../src/std/dev/devLiSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbbiDirectSoftCallback.obj -c ../../../src/std/dev/devMbbiDirectSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbbiSoftCallback.obj -c ../../../src/std/dev/devMbbiSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devSiSoftCallback.obj -c ../../../src/std/dev/devSiSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devAoSoftCallback.obj -c ../../../src/std/dev/devAoSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devBoSoftCallback.obj -c ../../../src/std/dev/devBoSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devCalcoutSoftCallback.obj -c ../../../src/std/dev/devCalcoutSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLoSoftCallback.obj -c ../../../src/std/dev/devLoSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devLsoSoftCallback.obj -c ../../../src/std/dev/devLsoSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbboSoftCallback.obj -c ../../../src/std/dev/devMbboSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devMbboDirectSoftCallback.obj -c ../../../src/std/dev/devMbboDirectSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devPrintfSoftCallback.obj -c ../../../src/std/dev/devPrintfSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devSoSoftCallback.obj -c ../../../src/std/dev/devSoSoftCallback.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devTimestamp.obj -c ../../../src/std/dev/devTimestamp.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o devStdio.obj -c ../../../src/std/dev/devStdio.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o asSubRecordFunctions.obj -c ../../../src/std/dev/asSubRecordFunctions.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o ts.obj -c ../../../src/std/filters/ts.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o dbnd.obj -c ../../../src/std/filters/dbnd.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o arr.obj -c ../../../src/std/filters/arr.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o sync.obj -c ../../../src/std/filters/sync.c
windres -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include ../dbRecStd.rc dbRecStd.coff
g++ -o dbRecStd.dll -shared -Wl,--out-implib,libdbRecStd.dll.a -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -m64 aaiRecord.obj aaoRecord.obj aiRecord.obj aoRecord.obj aSubRecord.obj biRecord.obj boRecord.obj calcRecord.obj calcoutRecord.obj compressRecord.obj dfanoutRecord.obj eventRecord.obj fanoutRecord.obj histogramRecord.obj longinRecord.obj longoutRecord.obj lsiRecord.obj lsoRecord.obj mbbiRecord.obj mbbiDirectRecord.obj mbboRecord.obj mbboDirectRecord.obj permissiveRecord.obj printfRecord.obj selRecord.obj seqRecord.obj stateRecord.obj stringinRecord.obj stringoutRecord.obj subRecord.obj subArrayRecord.obj waveformRecord.obj devAaiSoft.obj devAaoSoft.obj devAiSoft.obj devAiSoftRaw.obj devAoSoft.obj devAoSoftRaw.obj devBiSoft.obj devBiSoftRaw.obj devBiDbState.obj devBoSoft.obj devBoSoftRaw.obj devBoDbState.obj devCalcoutSoft.obj devEventSoft.obj devHistogramSoft.obj devLiSoft.obj devLoSoft.obj devLsiSoft.o!
bj devLsoSoft.obj devMbbiDirectSoft.obj devMbbiDirectSoftRaw.obj devMbbiSoft.obj devMbbiSoftRaw.obj devMbboDirectSoft.obj devMbboDirectSoftRaw.obj devMbboSoft.obj devMbboSoftRaw.obj devPrintfSoft.obj devSASoft.obj devSiSoft.obj devSoSoft.obj devWfSoft.obj devGeneralTime.obj devAiSoftCallback.obj devBiSoftCallback.obj devLiSoftCallback.obj devMbbiDirectSoftCallback.obj devMbbiSoftCallback.obj devSiSoftCallback.obj devAoSoftCallback.obj devBoSoftCallback.obj devCalcoutSoftCallback.obj devLoSoftCallback.obj devLsoSoftCallback.obj devMbboSoftCallback.obj devMbboDirectSoftCallback.obj devPrintfSoftCallback.obj devSoSoftCallback.obj devTimestamp.obj devStdio.obj asSubRecordFunctions.obj ts.obj dbnd.obj arr.obj sync.obj dbRecStd.coff -ldbCore -lca -lCom -lpthread -lm
Installing shared library ../../../bin/cygwin-x86_64/dbRecStd.dll
Installing library ../../../lib/cygwin-x86_64/libdbRecStd.dll.a
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o softIoc_registerRecordDeviceDriver.obj -c softIoc_registerRecordDeviceDriver.cpp
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../include/compiler/gcc -I../../../include/os/cygwin32 -I../../../include -o softMain.obj -c ../../../src/std/softIoc/softMain.cpp
g++ -o softIoc.exe -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -m64 softIoc_registerRecordDeviceDriver.obj softMain.obj -ldbRecStd -ldbCore -lca -lCom
Installing created executable ../../../bin/cygwin-x86_64/softIoc.exe
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl> -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aoRecord.html ../../../src/std/rec/aoRecord.dbd.pod
Installing generated html ../../../html/./aoRecord.html
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl> -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aSubRecord.html ../../../src/std/rec/aSubRecord.dbd.pod
Installing generated html ../../../html/./aSubRecord.html
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl> -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o waveformRecord.html ../../../src/std/rec/waveformRecord.dbd.pod
Installing generated html ../../../html/./waveformRecord.html
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl> -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o compressRecord.html ../../../src/std/rec/compressRecord.dbd.pod
Installing generated html ../../../html/./compressRecord.html
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl> -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o aiRecord.html ../../../src/std/rec/aiRecord.dbd.pod
Installing generated html ../../../html/./aiRecord.html
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToHtml.pl> -I. -I.. -I../O.Common -I../../../src/std/rec -I../../../src/std/dev -I../../../src/std/filters -I../../../src/std/softIoc -I../../../dbd -o filters.html ../../../src/std/filters/filters.dbd.pod
Installing generated html ../../../html/./filters.html
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std'>
make -C std/filters/test install
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test'>
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/makeMakefile.pl> O.cygwin-x86_64 ../../../../..
mkdir O.Common
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../../.. \
T_A=cygwin-x86_64 install
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test/O.cygwin-x86_64'>
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToRecordtypeH.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o arrRecord.h ../arrRecord.dbd
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF arrRecord.d -MT arrRecord.obj ../arrRecord.c
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdToRecordtypeH.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o xRecord.h ../xRecord.dbd
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF xRecord.d -MT xRecord.obj ../xRecord.c
Creating dbd file syncTest.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o syncTest.dbd xRecord.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o syncTest_registerRecordDeviceDriver.cpp ../O.Common/syncTest.dbd syncTest_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF syncTest_registerRecordDeviceDriver.d -MT syncTest_registerRecordDeviceDriver.obj syncTest_registerRecordDeviceDriver.cpp
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF syncTest.d -MT syncTest.obj ../syncTest.c
Creating dbd file arrTest.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o arrTest.dbd arrRecord.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o arrTest_registerRecordDeviceDriver.cpp ../O.Common/arrTest.dbd arrTest_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF arrTest_registerRecordDeviceDriver.d -MT arrTest_registerRecordDeviceDriver.obj arrTest_registerRecordDeviceDriver.cpp
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF arrTest.d -MT arrTest.obj ../arrTest.cpp
Creating dbd file dbndTest.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o dbndTest.dbd xRecord.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o dbndTest_registerRecordDeviceDriver.cpp ../O.Common/dbndTest.dbd dbndTest_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF dbndTest_registerRecordDeviceDriver.d -MT dbndTest_registerRecordDeviceDriver.obj dbndTest_registerRecordDeviceDriver.cpp
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF dbndTest.d -MT dbndTest.obj ../dbndTest.c
Creating dbd file tsTest.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o tsTest.dbd xRecord.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o tsTest_registerRecordDeviceDriver.cpp ../O.Common/tsTest.dbd tsTest_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF tsTest_registerRecordDeviceDriver.d -MT tsTest_registerRecordDeviceDriver.obj tsTest_registerRecordDeviceDriver.cpp
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF tsTest.d -MT tsTest.obj ../tsTest.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o xRecord.obj -c ../xRecord.c
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o arrRecord.obj -c ../arrRecord.c
g++ -o Recs.dll -shared -Wl,--out-implib,libRecs.dll.a -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -m64 xRecord.obj arrRecord.obj -ldbCore -lCom -lpthread -lm
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o tsTest.obj -c ../tsTest.c
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o tsTest_registerRecordDeviceDriver.obj -c tsTest_registerRecordDeviceDriver.cpp
g++ -o tsTest.exe -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test/O.cygwin-x86_64> -m64 tsTest.obj tsTest_registerRecordDeviceDriver.obj -lRecs -ldbRecStd -ldbCore -lca -lCom
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o dbndTest.obj -c ../dbndTest.c
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o dbndTest_registerRecordDeviceDriver.obj -c dbndTest_registerRecordDeviceDriver.cpp
g++ -o dbndTest.exe -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test/O.cygwin-x86_64> -m64 dbndTest.obj dbndTest_registerRecordDeviceDriver.obj -lRecs -ldbRecStd -ldbCore -lca -lCom
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o arrTest.obj -c ../arrTest.cpp
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o arrTest_registerRecordDeviceDriver.obj -c arrTest_registerRecordDeviceDriver.cpp
g++ -o arrTest.exe -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test/O.cygwin-x86_64> -m64 arrTest.obj arrTest_registerRecordDeviceDriver.obj -lRecs -ldbRecStd -ldbCore -lca -lCom
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o syncTest.obj -c ../syncTest.c
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -o syncTest_registerRecordDeviceDriver.obj -c syncTest_registerRecordDeviceDriver.cpp
g++ -o syncTest.exe -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/lib/cygwin-x86_64> -L/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test/O.cygwin-x86_64> -m64 syncTest.obj syncTest_registerRecordDeviceDriver.obj -lRecs -ldbRecStd -ldbCore -lca -lCom
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/makeTestfile.pl> tsTest.t tsTest.exe
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/makeTestfile.pl> dbndTest.t dbndTest.exe
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/makeTestfile.pl> arrTest.t arrTest.exe
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/makeTestfile.pl> syncTest.t syncTest.exe
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/filters/test'>
make -C std/rec/test install
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/rec/test'>
mkdir O.Common
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/rec/test/O.cygwin-x86_64'>
Creating dbd file analogMonitorTest.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o analogMonitorTest.dbd base.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o analogMonitorTest_registerRecordDeviceDriver.cpp ../O.Common/analogMonitorTest.dbd analogMonitorTest_registerRecordDeviceDriver /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
g++ -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF analogMonitorTest_registerRecordDeviceDriver.d -MT analogMonitorTest_registerRecordDeviceDriver.obj analogMonitorTest_registerRecordDeviceDriver.cpp
gcc -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/cygwin32 -I../../../../../include -MM -MF analogMonitorTest.d -MT analogMonitorTest.obj ../analogMonitorTest.c
Creating dbd file asTestIoc.dbd
perl -CSD /cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/bin/cygwin-x86_64/dbdExpand.pl> -I. -I.. -I../O.Common -I../../../../../dbd -o asTestIoc.dbd base.dbd asTest.dbd
dbdExpand.pl: Can't find file 'asTest.dbd'
while reading 'asTest.dbd' to create 'asTestIoc.dbd'
Your Makefile may need this dependency rule:
$(COMMON_DIR)/asTestIoc.dbd: $(COMMON_DIR)/asTest.dbd
dbdExpand.pl: Exiting due to errors
../../../../../configure/RULES.Db:402: recipe for target '../O.Common/asTestIoc.dbd' failed
make[3]: *** [../O.Common/asTestIoc.dbd] Error 2
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/rec/test/O.cygwin-x86_64'>
../../../../configure/RULES_ARCHS:61: recipe for target 'install.cygwin-x86_64' failed
make[2]: *** [install.cygwin-x86_64] Error 2
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src/std/rec/test'>
../configure/RULES_DIRS:88: recipe for target 'std/rec/test.install' failed
make[1]: *** [std/rec/test.install] Error 2
make[1]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/src'>
configure/RULES_DIRS:88: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-base-3.16-cyg64 #23 APS Jenkins
- Build failed in Jenkins: epics-base-3.16-cyg64 #21 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win32s #20 APS Jenkins
Re: DBD/DB validator? Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
