2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-cyg64 #197
To: [email protected]
Date: Wed, 29 Apr 2015 12:35:04 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/197/changes>
Changes:
[Ralph Lange] configure: set version snapshot to -rc1-DEV
[Ralph Lange] configure: update CONFIG_BASE_VERSION for 3.15.2-rc1
[...truncated 2144 lines...]
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
epicsThreadSetPriority called by non epics thread
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD epicsExceptionTest.t -tap > epicsExceptionTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
/bin/sh: perl: command not found
../../../../configure/RULES_BUILD:336: recipe for target 'blockingSockTest.tap' failed
make[3]: [blockingSockTest.tap] Error 127 (ignored)
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
../../../../configure/RULES_BUILD:336: recipe for target 'epicsMessageQueueTest.tap' failed
make[3]: [epicsMessageQueueTest.tap] Error 127 (ignored)
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
../../../../configure/RULES_BUILD:336: recipe for target 'epicsStackTraceTest.tap' failed
make[3]: [epicsStackTraceTest.tap] Error 127 (ignored)
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/libCom/test/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/libCom/test'>
make -C ca/client tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client'>
make[2]: perl: Command not found
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=cygwin-x86_64 tapfiles
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/O.cygwin-x86_64'>
make[3]: perl: Command not found
make[3]: Nothing to be done for 'tapfiles'.
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client'>
make -C ca/client/tools tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/tools'>
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../../.. \
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/tools/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/tools/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/tools'>
make -C ca/legacy/gdd tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/gdd'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/gdd/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/gdd/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/gdd'>
make -C ca/legacy/pcas tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas'>
make -C ./build tapfiles
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/build'>
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../../../.. \
make[4]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/build/O.cygwin-x86_64'>
make[4]: perl: Command not found
make[4]: Nothing to be done for 'tapfiles'.
make[4]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/build/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/build'>
make -C ./example tapfiles
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/example'>
make -C ./directoryService tapfiles
make[4]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/example/directoryService'>
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../../../../../.. \
make[5]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/example/directoryService/O.cygwin-x86_64'>
make[5]: perl: Command not found
make[5]: Nothing to be done for 'tapfiles'.
make[5]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/example/directoryService/O.cygwin-x86_64'>
make[4]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/example/directoryService'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/example'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas'>
make -C ./ioc tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc'>
make -C O.cygwin-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc'>
make -C ca/legacy/pcas/ex tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/legacy/pcas/ex'>
make -C ca/client/perl tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ca/client/perl'>
make -C ioc/db/test tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64'>
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbShutdownTest.tap' failed
make[3]: [dbShutdownTest.tap] Error 127 (ignored)
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbPutLinkTest.tap' failed
make[3]: [dbPutLinkTest.tap] Error 127 (ignored)
perl -CSD dbLockTest.t -tap > dbLockTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbLockTest.tap' failed
make[3]: [dbLockTest.tap] Error 127 (ignored)
perl -CSD testdbConvert.t -tap > testdbConvert.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'testdbConvert.tap' failed
make[3]: [testdbConvert.tap] Error 127 (ignored)
perl -CSD callbackTest.t -tap > callbackTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'callbackTest.tap' failed
make[3]: [callbackTest.tap] Error 127 (ignored)
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'callbackParallelTest.tap' failed
make[3]: [callbackParallelTest.tap] Error 127 (ignored)
perl -CSD dbStateTest.t -tap > dbStateTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbStateTest.tap' failed
make[3]: [dbStateTest.tap] Error 127 (ignored)
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbCaStatsTest.tap' failed
make[3]: [dbCaStatsTest.tap] Error 127 (ignored)
perl -CSD scanIoTest.t -tap > scanIoTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'scanIoTest.tap' failed
make[3]: [scanIoTest.tap] Error 127 (ignored)
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbChannelTest.tap' failed
make[3]: [dbChannelTest.tap] Error 127 (ignored)
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'chfPluginTest.tap' failed
make[3]: [chfPluginTest.tap] Error 127 (ignored)
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'arrShorthandTest.tap' failed
make[3]: [arrShorthandTest.tap] Error 127 (ignored)
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'recGblCheckDeadbandTest.tap' failed
make[3]: [recGblCheckDeadbandTest.tap] Error 127 (ignored)
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/db/test'>
make -C ioc/dbtemplate/test tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/dbtemplate/test'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/dbtemplate/test/O.cygwin-x86_64'>
perl -CSD msi.t -tap > msi.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'msi.tap' failed
make[3]: [msi.tap] Error 127 (ignored)
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/dbtemplate/test/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/ioc/dbtemplate/test'>
make -C ./std tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/O.cygwin-x86_64'>
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std'>
make -C std/filters/test tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/filters/test'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/filters/test/O.cygwin-x86_64'>
perl -CSD tsTest.t -tap > tsTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'tsTest.tap' failed
make[3]: [tsTest.tap] Error 127 (ignored)
perl -CSD dbndTest.t -tap > dbndTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'dbndTest.tap' failed
make[3]: [dbndTest.tap] Error 127 (ignored)
perl -CSD arrTest.t -tap > arrTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'arrTest.tap' failed
make[3]: [arrTest.tap] Error 127 (ignored)
perl -CSD syncTest.t -tap > syncTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'syncTest.tap' failed
make[3]: [syncTest.tap] Error 127 (ignored)
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/filters/test/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/filters/test'>
make -C std/rec/test tapfiles
make[2]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/rec/test'>
make[3]: Entering directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/rec/test/O.cygwin-x86_64'>
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'arrayOpTest.tap' failed
make[3]: [arrayOpTest.tap] Error 127 (ignored)
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
../../../../../configure/RULES_BUILD:336: recipe for target 'analogMonitorTest.tap' failed
make[3]: [analogMonitorTest.tap] Error 127 (ignored)
make[3]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/rec/test/O.cygwin-x86_64'>
make[2]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src/std/rec/test'>
make[1]: Leaving directory '/cygdrive/c<https://jenkins.aps.anl.gov/job/epics-base-3.15-cyg64/ws/src'>
+ find src -path '*/O.cygwin-x86_64/*.tap'
+ prove -e cat -
C:\Users\jenkins\hudson2567596850215403371.sh: line 9: prove: command not found
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.15-cyg64 #198 APS Jenkins
Build failed in Jenkins: epics-base-3.15-cyg64 #196 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.15-cyg64 #196 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-cyg64 #198 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
