2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-cyg64 #27
To: [email protected]
Date: Fri, 5 Jun 2015 16:24:07 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/27/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on cyg64-1 (cyg64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/> returned 0. Command output: "12651 [email protected]
" stderr: ""
[epics-base-3.16-cyg64] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.16-cyg64] $ bzr pull --overwrite lp:epics-base/3.16/
bzr: ERROR: Cannot lock LockDir(file:///C:<https://jenkins.aps.anl.gov/job/epics-base-3.16-cyg64/ws/.bzr/branch/lock)>: Permission denied: "lock/6z4hxk7s8y.tmp/info": [Errno 13] Permission denied
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.16-cyg64 #28 APS Jenkins
Build failed in Jenkins: epics-base-3.16-cyg64 #26 APS Jenkins
Prev: Build failed in Jenkins: epics-base-3.16-cyg64 #26 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-cyg64 #28 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
