Hi Matej,
On 06/29/2015 04:55 AM, Matej Sekoranja wrote:
> Hi Andrew,
> I started looking into this.
> … and I’ve found out that the API is already there:
> class epicsShareClass casChannel {
> public:
> casChannel ( const casCtx & ctx );
> virtual ~casChannel ();
> // Called when the user name and the host name are changed
> // for a live connection.
> virtual void setOwner ( const char * const pUserName,
> const char * const pHostName );
> The casChannel::setOwner method.
> I think this is what you wanted, right?
> (It just needs to be called when username is changed.)
That looks like the right method. Most existing CAS applications
probably don't implement it though; this is from the PV Gateway's
gateVc.cc file:
> #ifdef SUPPORT_OWNER_CHANGE
> // Virtual function from casChannel, not called from Gateway. It is a
> // security hole to support this, and it is no longer implemented in
> // base.
> void gateChan::setOwner(const char* const u, const char* const h)
> asclient->changeInfo(u,h);
> #endif
The SUPPORT_OWNER_CHANGE macro is not defined in the gateway build, and
that method is similarly #ifdef'd out in the related header file. The
routine it calls is defined inline in gateAs.h:
> // Used in virtual function setOwner from casChannel, not called
> // from Gateway. It is a security hole to support this, and it is
> // no longer implemented in base.
> long changeInfo(const char* user, const char* host)
> { return asChangeClient(asclientpvt,asentry->level,(char*)user,(char*)host);}
> #endif
Re-enabling this functionality in the gateway will obviously need
careful testing, but I guess the RBAC implementation will be making more
changes to the gateway anyhow.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
-- Terry Pratchett, Reaper Man
Re: Base development meetings Michael Davidsaver
Build failed in Jenkins: epics-base-3.16-win32 #25 APS Jenkins
<2015>
2025
2026
Jenkins build is back to stable : epics-base-3.16-mac #27 APS Jenkins
STATIC_ASSERT and -Wunused-local-typedefs Michael Davidsaver
<2015>
2025
2026
