2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Gateway support for DBE_PROPERTY
To: "Shankar, Murali" <[email protected]>, EPICS Core-Talk <[email protected]>
Date: Fri, 10 Jul 2015 09:07:26 +0200
All,
I have merged the dbe_props branch [1] (adding full support for the DBE_PROPERTY event flag) into the CA Gateway trunk, and added running the tests and showing the results to the CI Jenkins jobs at CloudBees [2]. (Looks nice!)
@Murali: Can you continue with your tests as SLAC with a DEV-version Gateway from trunk, or do you want me to push out an official release? Naturally I would rather have you do some stress testing (archiverappliance) before I release, but I could also just start the releasing process so you could test on a -pre1.
There are some minor things (Makefile stuff, clean-up, doc update, a few more tests) that I would like to include in the next release - no planned critical changes.
Cheers,
~Ralph
[1] https://code.launchpad.net/~epics-core/epics-gateway/dbe_props/+merge/262832
[2] https://openepics.ci.cloudbees.com/job/CA_Gateway/
Re: CA Gateway support for DBE_PROPERTY Shankar, Murali
Prev: Build failed in Jenkins: epics-base-3.16-mac-test #4 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-mac-test #5 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.16-mac-test #6 APS Jenkins
Next: Re: CA Gateway support for DBE_PROPERTY Shankar, Murali
