2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-mac-test #13
To: [email protected]
Date: Thu, 23 Jul 2015 18:18:44 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/13/>
Started by upstream project "epics-base-3.15-mac" build number 53
originally caused by:
 Started by upstream project "epics-base-3.15" build number 217
  Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-mac-test/ws/>
[epics-base-3.15-mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/hudson6647758684459477080.sh
+ make -C src tapfiles CROSS_COMPILER_TARGET_ARCHS=
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./tools tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
	    T_A=darwin-x86 tapfiles
make[2]: Nothing to be done for `tapfiles'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C tools/test tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../.. \
perl -CSD Breaktable.t -tap > Breaktable.tap
perl -CSD DBD.t -tap > DBD.tap
perl -CSD Device.t -tap > Device.tap
perl -CSD Driver.t -tap > Driver.tap
perl -CSD Function.t -tap > Function.tap
perl -CSD macLib.t -tap > macLib.tap
perl -CSD Menu.t -tap > Menu.tap
perl -CSD Recfield.t -tap > Recfield.tap
perl -CSD Recordtype.t -tap > Recordtype.tap
perl -CSD Registrar.t -tap > Registrar.tap
perl -CSD Variable.t -tap > Variable.tap
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C template/base tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C template/ext tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./libCom tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C libCom/RTEMS tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C libCom/test tapfiles
perl -CSD epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
perl -CSD epicsTypesTest.t -tap > epicsTypesTest.tap
perl -CSD epicsInlineTest.t -tap > epicsInlineTest.tap
perl -CSD epicsCalcTest.t -tap > epicsCalcTest.tap
perl -CSD epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
perl -CSD epicsMathTest.t -tap > epicsMathTest.tap
perl -CSD epicsMMIOTest.t -tap > epicsMMIOTest.tap
perl -CSD epicsEllTest.t -tap > epicsEllTest.tap
perl -CSD epicsEnvTest.t -tap > epicsEnvTest.tap
perl -CSD epicsErrlogTest.t -tap > epicsErrlogTest.tap
log client: connected to log server at "127.0.0.1:54377"
perl -CSD epicsStdioTest.t -tap > epicsStdioTest.tap
perl -CSD epicsStdlibTest.t -tap > epicsStdlibTest.tap
perl -CSD epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
perl -CSD epicsStringTest.t -tap > epicsStringTest.tap
perl -CSD epicsTimeTest.t -tap > epicsTimeTest.tap
perl -CSD epicsThreadTest.t -tap > epicsThreadTest.tap
perl -CSD epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
perl -CSD epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl -CSD epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl -CSD epicsThreadHooksTest.t -tap > epicsThreadHooksTest.tap
perl -CSD epicsThreadPoolTest.t -tap > epicsThreadPoolTest.tap
perl -CSD epicsExitTest.t -tap > epicsExitTest.tap
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
epicsThreadSetPriority called by non epics thread
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD epicsExceptionTest.t -tap > epicsExceptionTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ca/client tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ca/client/tools tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ca/legacy/gdd tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ca/legacy/pcas tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./build tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../../.. \
make[3]: Nothing to be done for `tapfiles'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./example tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./directoryService tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../../../.. \
make[4]: Nothing to be done for `tapfiles'.
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./ioc tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ca/legacy/pcas/ex tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ca/client/perl tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ioc/db/test tapfiles
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
Starting iocInit
Starting iocInit
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ioc/dbtemplate/test tapfiles
perl -CSD msi.t -tap > msi.tap
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C ./std tapfiles
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C std/filters/test tapfiles
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
Starting iocInit
../../../src/ioc/rsrv/online_notify.c: CA beacon routing (connect to "127.0.0.1:5065") error was "Connection refused"
perl -CSD syncTest.t -tap > syncTest.tap
/Applications/Xcode.app/Contents/Developer/usr/bin/make -C std/rec/test tapfiles
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
+ prove --recurse --ext .tap --exec cat src
src/ioc/db/test/O.darwin-x86/arrShorthandTest.tap ......... ok
src/ioc/db/test/O.darwin-x86/callbackParallelTest.tap ..... ok
src/ioc/db/test/O.darwin-x86/callbackTest.tap .............
Failed 12/339 subtests
src/ioc/db/test/O.darwin-x86/chfPluginTest.tap ............ ok
src/ioc/db/test/O.darwin-x86/dbCaStatsTest.tap ............ ok
src/ioc/db/test/O.darwin-x86/dbChannelTest.tap ............ ok
src/ioc/db/test/O.darwin-x86/dbLockTest.tap ............... ok
src/ioc/db/test/O.darwin-x86/dbPutLinkTest.tap ............ ok
src/ioc/db/test/O.darwin-x86/dbShutdownTest.tap ........... ok
src/ioc/db/test/O.darwin-x86/dbStateTest.tap .............. ok
src/ioc/db/test/O.darwin-x86/recGblCheckDeadbandTest.tap .. ok
src/ioc/db/test/O.darwin-x86/scanIoTest.tap ............... ok
src/ioc/db/test/O.darwin-x86/testdbConvert.tap ............ ok
src/ioc/dbtemplate/test/O.darwin-x86/msi.tap .............. ok
src/libCom/test/O.darwin-x86/blockingSockTest.tap ......... ok
src/libCom/test/O.darwin-x86/epicsAlgorithmTest.tap ....... ok
src/libCom/test/O.darwin-x86/epicsAtomicTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsCalcTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsEllTest.tap ............. ok
src/libCom/test/O.darwin-x86/epicsEnvTest.tap ............. ok
src/libCom/test/O.darwin-x86/epicsErrlogTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsEventTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsExceptionTest.tap ....... ok
src/libCom/test/O.darwin-x86/epicsExitTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsInlineTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsMMIOTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsMathTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsMessageQueueTest.tap .... ok
src/libCom/test/O.darwin-x86/epicsMutexTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsSockResolveTest.tap ..... ok
src/libCom/test/O.darwin-x86/epicsSpinTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsStackTraceTest.tap ...... ok
src/libCom/test/O.darwin-x86/epicsStdioTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsStdlibTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsStringTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsThreadHooksTest.tap ..... ok
src/libCom/test/O.darwin-x86/epicsThreadOnceTest.tap ...... ok
src/libCom/test/O.darwin-x86/epicsThreadPoolTest.tap ...... ok
src/libCom/test/O.darwin-x86/epicsThreadPriorityTest.tap .. ok
src/libCom/test/O.darwin-x86/epicsThreadPrivateTest.tap ... ok
src/libCom/test/O.darwin-x86/epicsThreadTest.tap .......... ok
src/libCom/test/O.darwin-x86/epicsTimeTest.tap ............ ok
src/libCom/test/O.darwin-x86/epicsTimerTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsTypesTest.tap ........... ok
src/libCom/test/O.darwin-x86/epicsUnitTestTest.tap ........ ok
src/libCom/test/O.darwin-x86/macDefExpandTest.tap ......... ok
src/libCom/test/O.darwin-x86/macLibTest.tap ............... ok
src/libCom/test/O.darwin-x86/ringBytesTest.tap ............ ok
src/libCom/test/O.darwin-x86/ringPointerTest.tap .......... ok
src/libCom/test/O.darwin-x86/taskwdTest.tap ............... ok
src/std/filters/test/O.darwin-x86/arrTest.tap ............. ok
src/std/filters/test/O.darwin-x86/dbndTest.tap ............ ok
src/std/filters/test/O.darwin-x86/syncTest.tap ............ ok
src/std/filters/test/O.darwin-x86/tsTest.tap .............. ok
src/std/rec/test/O.darwin-x86/analogMonitorTest.tap ....... ok
src/std/rec/test/O.darwin-x86/arrayOpTest.tap ............. ok
src/tools/test/O.darwin-x86/Breaktable.tap ................ ok
src/tools/test/O.darwin-x86/DBD.tap ....................... ok
src/tools/test/O.darwin-x86/Device.tap .................... ok
src/tools/test/O.darwin-x86/Driver.tap .................... ok
src/tools/test/O.darwin-x86/Function.tap .................. ok
src/tools/test/O.darwin-x86/Menu.tap ...................... ok
src/tools/test/O.darwin-x86/Recfield.tap .................. ok
src/tools/test/O.darwin-x86/Recordtype.tap ................ ok
src/tools/test/O.darwin-x86/Registrar.tap ................. ok
src/tools/test/O.darwin-x86/Variable.tap .................. ok
src/tools/test/O.darwin-x86/macLib.tap .................... ok
Test Summary Report
src/ioc/db/test/O.darwin-x86/callbackTest.tap           (Wstat: 0 Tests: 339 Failed: 12)
  Failed tests:  255-266
Files=67, Tests=8894,  1 wallclock secs ( 0.64 usr  0.07 sys +  0.14 cusr  0.12 csys =  0.97 CPU)
Result: FAIL
Build step 'Execute shell' marked build as failure
Build failed in Jenkins: epics-base-3.15-mac-test #14 APS Jenkins
Prev: Jenkins build is back to stable : epics-base-3.15-win64s #173 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.15-mac-test #14 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-base-3.15-win64 #190 APS Jenkins
