2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.14-sol #1
To: [email protected]
Date: Mon, 3 Aug 2015 11:13:49 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/1/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on sol-1 (sol-sparc) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/>
Cleaning workspace...
$ bzr branch bzr+ssh://bazaar.launchpad.net/%2Bbranch/epics-base/3.14/ <https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/>
Host key verification failed.
bzr: ERROR: Connection closed: Unexpected end of message. Please check connectivity and permissions, and report a bug if problems persist.
ERROR: Failed to branch bzr+ssh://bazaar.launchpad.net/%2Bbranch/epics-base/3.14/
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.solaris-sparc/*.tap
ERROR: Build step failed with exception
<https://jenkins.aps.anl.gov/job/epics-base-3.14-sol/ws/> does not exist.
	at org.apache.tools.ant.types.AbstractFileSet.getDirectoryScanner(AbstractFileSet.java:483)
	at hudson.FilePath.glob(FilePath.java:1740)
	at hudson.FilePath.access$1700(FilePath.java:191)
	at hudson.FilePath$32.invoke(FilePath.java:1718)
	at hudson.FilePath$32.invoke(FilePath.java:1715)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2688)
	at hudson.remoting.UserRequest.perform(UserRequest.java:121)
	at hudson.remoting.UserRequest.perform(UserRequest.java:49)
	at hudson.remoting.Request$2.run(Request.java:325)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
	at java.lang.Thread.run(Thread.java:682)
	at ......remote call to sol-1(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1360)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:221)
	at hudson.remoting.Channel.call(Channel.java:753)
	at hudson.FilePath.act(FilePath.java:978)
	at hudson.FilePath.act(FilePath.java:967)
	at hudson.FilePath.list(FilePath.java:1715)
	at hudson.FilePath.list(FilePath.java:1700)
	at hudson.FilePath.list(FilePath.java:1686)
	at org.tap4j.plugin.TapPublisher.locateReports(TapPublisher.java:438)
	at org.tap4j.plugin.TapPublisher.perform(TapPublisher.java:224)
	at hudson.tasks.BuildStepMonitor$2.perform(BuildStepMonitor.java:32)
	at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:761)
	at hudson.model.AbstractBuild$AbstractBuildExecution.performAllBuildSteps(AbstractBuild.java:721)
	at hudson.model.Build$BuildExecution.post2(Build.java:183)
	at hudson.model.AbstractBuild$AbstractBuildExecution.post(AbstractBuild.java:670)
	at hudson.model.Run.execute(Run.java:1766)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:374)
Build step 'Publish TAP Results' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-base-3.14-sol #2 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.14-vx69 #92 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.14-sol #2 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
