2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Successfully locked memory using mlockAll
To: Ralph Lange <[email protected]>, EPICS core-talk <[email protected]>
Date: Mon, 23 Nov 2015 16:17:10 -0600
Hi Ralph,
On 11/23/2015 03:54 PM, Ralph Lange wrote:
> You're definitely right in this case, but when you use the
> appropriate configuration (from our wiki), you'll be facing that same
> issue without being root.
> I guess we never thought about this memlocking thing being done when
> you start a client on a real-time system. Doesn't make much sense to
> memlock, but running a client on a real-time system is certainly
> legal.
I was never completely happy with this mlockall() solution but didn't
really know why until now. On Solaris the IOC and all our test programs
print the message "Unable to lock the virtual address space using
mlockall" to stderr from the same block of code, which I would also like
a solution for.
I think it probably makes more sense for the application itself (i.e.
the IOC's startup script) to explicitly ask for mlockall() to be called,
but I don't know whether we could implement that level of change in 3.15.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Successfully locked memory using mlockAll Michael Davidsaver
Prev: stupid git trick Michael Davidsaver
Next: Re: Successfully locked memory using mlockAll Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
