ASYN has never allowed multiplexing multiple transactions through a single socket like that. Mark’s proposed change of recv to recvfrom is simply to provide additional information for diagnostic messages. The other changes (use sendto rather than connect/send for SOCK_DGRAM sockets) is to support devices which respond to UDP broadcasts.
May be unrelated. (And may be we should have the comments on Github.)
Can we cover the following example ?
Our EPICS IOC 192.168.0.14 ———> UDP ———> AsynUser 1 reads it. Does some processing. sleeping…
192.168.0.15 ———> UDP ———> AsynUser 2 reads it. Does some processing. sleeping… AsynUser 1 wants to answer. Does the answer go to 192.168.0.14 ? Or does it go to 192.168.0.15 ??
This only seems to be correct if the messages are processed sequentially, first receiving, then consuming the message, then receiving one more message and so on. If the code allows receiving and consuming the messages out of order, then this is mixing the messages source addresses in tty-> farAddr.oa.sa.
If necessary, the remote address should be linked to the message, not to the socket, and consumed with it.
- RE: Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
- Proposed change to asyn drvAsynIPPort for UDP sockets Mark Rivers
- Re: Proposed change to asyn drvAsynIPPort for UDP sockets Henrique Almeida
- Re: Proposed change to asyn drvAsynIPPort for UDP sockets Torsten bögershaus
<2015>
2025
2026
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
